Page 21 of 37
Re: TF536 + 68000 relocator and ROM board project.
Posted: 01 Nov 2020 18:52
by stephen_usher
Oh, monitoring the ground over the other side of the board, next to the ROM... Spikey when the ROM is being accessed! (Once a game which doesn't use the ROM starts the ground goes quiet.)
OK, so it looks like the majority of the problems are probably too small decoupling caps. I can test this properly after Tuesday.
Posted: 02 Nov 2020 10:39
by stephen_usher
Seeing as I'm working from home today and had a little time this morning added 1uF tantallums on the current board.
The ground is a lot cleaner now, though still spikey directly next to the major chips, but maybe that's normal?
So, that's good isn't it?
Well, the strange thing is that the TF536 GB6 speeds have dropped significantly. e.g. the Integer Division score went from 1728% down to 1656% of a standard STFM.
Posted: 02 Nov 2020 11:42
by derkom
stephen_usher wrote: 02 Nov 2020 10:39
What about the 68000? Still at the unusual 99%?
Posted: 02 Nov 2020 12:14
by stephen_usher
Yeah, between 99% and 98% as usual.
Posted: 02 Nov 2020 13:31
by stephen_usher
I've put a 10K pull-up on /DTACK as from the 'scope trace that rises quite slowly relative to the width of the signal and hence could give a timing issue.
That's improved things very slightly on the 68000 giving 99% and 100% for many of the tests where they were 98% and 99%.
It hasn't improved the speed of the TF though and I have noticed the display jump to the right, as described by Exxos as clock skew. (However, I can't see any skew at all when using the oscilloscope.)
I'll try a 2K2 resistor later but I can't do that this afternoon.
Posted: 02 Nov 2020 14:03
The skew only needs to be like 2ns to upset it. It's easily missed.
Posted: 02 Nov 2020 16:25
by stephen_usher
Going to the highest sensitivity of my oscilloscope there seems to be a skew of around 0.25 to 0.5 ns at most across the board and onto the TF.
Posted: 02 Nov 2020 19:52
by stephen_usher
I've found out why the benchmarks for the TF are lower than I had before... I was an idiot!
The previous benchmark was done with the cache enabled! D-oh!
Turn on the cache and the benchmarks are the same.
Still, I can't find why the 68000 benchmark is lower. Surely a clock skew of less than half a nanosecond can't really be the reason.
Posted: 02 Nov 2020 20:27
Clock skew is visible with pixel issues , like the screen shifts 16 pixels to the right and wraps around to the next line.. try something like 500R on ST DTACK see if that helps.
Posted: 02 Nov 2020 21:06
by stephen_usher
As in pull-up?
