Page 3 of 5
Re: Booster V4sm problem
Posted: 18 Jan 2026 20:35
You don't say if you tried removing the ROM CE wire ?
But also I would suggest not having any physical switch on the ROM board while debugging. If there is a bad contact it could be causing problems.
Posted: 18 Jan 2026 20:40
by zfrenchy
sorry, yes I tried, no success, still black screen sometime in 32Mhz mode.
I will take a break on that for now, may be put back the STE to factory setup but keep the DualTOS, which was working very well.
Posted: 18 Jan 2026 20:42
Do you have a scope to make your both sides of the 32Mhz wire ?
You could also try soldering the 32mhz wire direct to pin1 of the GAL..As it sounds like the booster is not seeing the 32mhz at all..
Posted: 19 Jan 2026 15:28
by zfrenchy
yes, I have a scope, Tektronix 222.
My knowledge on using a scope is very limited, using the auto button is my best skill :D
Posted: 19 Jan 2026 15:37
zfrenchy wrote: 19 Jan 2026 15:28 using the auto button is my best skill :D
Mine also ;)
Posted: 19 Jan 2026 15:47
by zfrenchy
I will found a way to connect the scope on pin4 of U405, under the PSU.
I measure the resistance from pin4 U405 and the wire solder joint is 0.1 Ohm, from the wire solder joint to pin1 of the GAL is 68.1 Ohm.
Is it normal to you ?
Posted: 19 Jan 2026 15:51
zfrenchy wrote: 19 Jan 2026 15:47 I will found a way to connect the scope on pin4 of U405, under the PSU.
Yes because there is a 68R in series with that wire..
This is why I suggest connect the wire directly to pin1 of the GAL, because it bypasses that resistor..
I'm working on the assumption that for some reason the board does not "see" 32Mhz..
So if you measure with your scope what you see on U405 end of the wire.. then measure pin1 of the GAL , we can see if there is to much voltage drop there... I assume there is..
Posted: 19 Jan 2026 16:55
by zfrenchy
I cannot make it to fail this morning !!!! But still not having the ATARI logo and RAM test at boot.
Top trace is from the wire, bottom is the GAL pin1
Posted: 19 Jan 2026 17:01
by zfrenchy
STOP THE TRAIN, I HAVE A FAIL !!!!
here the scope, same settings, black screen in 32Mhz mode !!!
sorry, for some reason the photo is displaying like that in the forum.
Posted: 19 Jan 2026 17:02
zfrenchy wrote: 19 Jan 2026 16:55 I cannot make it to fail this morning !!!! But still not having the ATARI logo and RAM test at boot.
You know you only get the logo with TOS206 ?
Looks fine then..
I assume you changed U405 for the FAST series as the S version won't work.
