Page 3 of 11
Re: RISKY MSX Cart - Rev 1 (Beta Release)
Posted: 02 Feb 2025 21:22
by Higgy
Great progress.
If people need a Diagnostics program, then this can run from RiskyMSX:
https://nightfoxandco.com/?page_id=787
I don't think it will test your MSX memory through, I did not see a check memory option.
Posted: 02 Feb 2025 23:08
by arkadiusz.makarenko
A little bit more progress with terminal programming interface.
https://youtube.com/shorts/idnzhhMuWCY? ... eQdJwHHZq-
Posted: 04 Feb 2025 00:37
I have done fair amount of progress today.
I managed to implement some guards like too big file, navigation doesn't show empty pages if there is nothing to show.
I have added support for hot swappable USB (not on all stages, only file menu - it is good enough).
Auto programming files based on their names (like it was before based on filenames). This apparently is quite important feature for DEVs. If they want to test or debug issues on real msx, they wound prefer not to fight with menus on each flashing.
I think this is enough for next release. I will build it tomorrow and publish on GitHub.
...next HDD/FDD emulation - proof of concept.
I magically found another 6KB of space for firmware , so I can expand some features.
I am still waiting for Chinese suppliers to go back to normal after New Year, so I still have few days to complete SCC out circuit and order new PCBs.
Posted: 04 Feb 2025 13:28
I have released firmware v0.5 with GUI for flashing cart and auto programming based of old filename convention.
Posted: 04 Feb 2025 13:32
by PhilC
arkadiusz.makarenko wrote: 04 Feb 2025 13:28 I have released firmware v0.5 with GUI for plashing cart and auto programming based of old filename convention.
Cool now I've got it working, all I've got to do is work out how to reprogram it :D
Posted: 04 Feb 2025 18:10
PhilC wrote: 04 Feb 2025 13:32
What are your first impressions?
Posted: 04 Feb 2025 19:51
by Higgy
First impressions - simple to use and had a good success rate, but v0.5 sounds like it makes it almost a new device, so probably what is found on first firmware is now not applicable.
As sent in PM I am having issues with Win10 and 7 detecting the device to program with USB+USB cable
Posted: 04 Feb 2025 20:23
by PhilC
arkadiusz.makarenko wrote: 04 Feb 2025 18:10
I've not had a chance to update the firmware today but will do in the morning and will give you my impressions of the latest version but so far so good I think
Posted: 04 Feb 2025 20:36
Higgy wrote: 04 Feb 2025 19:51 First impressions - simple to use and had a good success rate, but v0.5 sounds like it makes it almost a new device, so probably what is found on first firmware is now not applicable.
You need to close B0 jumper closed before connecting to PC.
PS.
Still I can't remember if I had to have additional drivers, it has been a while since I did it. There are additional files in the WCHISPTool folder in case you were looking for them.
Edit:
I have updated firmware upgrade guide. There is still a lot of work with this. I need to record a guide with pictures and screenshots.
https://github.com/arkadiuszmakarenko/RISKYMSX
Posted: 05 Feb 2025 08:47
by Higgy
Thanks B0 sorted it, device found straight away. :D
Yes there are additional drivers in the folder which I installed.
Ran out of time to test, I did not read instructions properly that said hold 'Flash' while powering on, so I got just a normal MSX screen, then had to go to bed.
