OK, so progress is progress I suppose.
I think the problem with the A5000 is memory. I've removed everything and flattened the config down to just a floppy disk, so nothing else at all connected, and the 2MB RAM board removed. I then boot to desktop.
If I leave it long enough it just crashes, so no ifs, no buts, it gets all sorts of exception errors and on screen corruption. So I think I'll pull the board and look for signs of further corrosion around the RAM, or other damage (I thought I'd got it, but you never know) and see where that takes me. I'll likely re-cap it whilst it's apart.
Now over on to the BBC B. I found this when looking more closely at the FDD socket:
- IMG20241130164203.jpg (389.59 KiB) Viewed 416 times
Can you spot the bad thing? Wow I thought, gotcha now but I get the same error messages as before with the Gotek even after fixing that!
I think I need to pull the mainboard and double check for bad joints on the FDD socket, and I'll do some more digging around using a Gotek with a BBC in case I've done anything dumb.
I have already gone through the install instructions for the 177X floppy interface and that all looks fine, as does the 8271 installation.
Also, I get the same error with the machine that has the 8271 FDD controller installed. I know it isn't the cable as that is brand new and buzzes out perfectly, and it isn't power because I'm using a known good external PSU.
Bit of a head scratcher. Also I think my head is going to explode!
:dizzy:
