Page 3 of 4
Re: New SCSI Solutions for Atari/Amiga!
Posted: 07 Jun 2021 22:18
by Cyprian
@Steve what about RaSCSI speed?
Posted: 07 Jun 2021 22:37
by Steve
Cyprian wrote: 07 Jun 2021 22:18 @Steve what about RaSCSI speed?
Posted: 07 Jun 2021 23:35
by Cyprian
nice result
Posted: 08 Jun 2021 11:09
by Steve
Inception or what? The Falcon SSHing into its own RaSCSI :) I bet I could even enable X forwarding to run modern Linux apps on the Falcon X server :D
Posted: 08 Jun 2021 12:35
by beel1
Steve wrote: 07 Jun 2021 22:37
Seeing the heatsink: is your Pi overclocked?
I've never achieved more than 800kb/s with my stock Pi3B+ even on a SCSI adapter in a modern PC
Posted: 08 Jun 2021 14:04
by Steve
@beel1 No just stock clock speed. You're running a Rascsi also I assume? It could be the Micro-SD card, I am using a Sandisk C10 Ultra.
Posted: 08 Jun 2021 14:30
by Steve
@beel1 I just remembered, on the rascsi wiki it says that the rascsi.service software is single threaded - and the Pi Zero is single core, so it might help.
https://github.com/akuker/RASCSI/wiki/Benchmarks
I suspect that the Pi 0 got higher scores because the RaSCSI software only uses one core. This gives the Pi 0 a slight clock speed advantage
Posted: 08 Jun 2021 15:48
by PaulJ
Steve wrote: 07 Jun 2021 22:37 PXL_20210607_200032971.jpg
Thats not bad, a little better than the UltraSatan and a tad slower than the IDE interfaces. Guess I need to build the SW and try mine. :)
Posted: 10 Jun 2021 19:59
by DaveC
Looks like I got the BLUESCSI working ok with my STe and ICD adscsi adapter :mrgreen:
It didn't work powered off the SCSI cable or usb port though, had to use the berg connector for it.
Posted: 10 Jun 2021 20:21
by Steve
@DaveC Nice! Have you run some file transfers to test stability? I find that even if TOS transfers OK, Kobold will show if there are issues.
Here is a good disk error check program by PP:
AHPT94.zip
(7.07 KiB) Downloaded 205 times
