Page 3 of 6
Re: TRUDIE V5.2 (5 volt) pre-release install guide
Posted: 21 Jul 2021 23:37
alienkidmj12 wrote: 21 Jul 2021 23:07 it will go on latest h5 without further mods ?
Yep.
Posted: 25 Jul 2021 13:25
by PhilC
@exxos I've got my Trudie in and working great with the H5C1, I'm going to fit an RGB led in place of the keyboard Led, I presume the other two wires for the leds were just +ve feeds to another led?
Posted: 25 Jul 2021 13:45
PhilC wrote: 25 Jul 2021 13:25 @exxos I've got my Trudie in and working great with the H5C1, I'm going to fit an RGB led in place of the keyboard Led, I presume the other two wires for the leds were just +ve feeds to another led?
You need the led & PCB... @JezC was asking about them last week, I've not had chance to look for them yet.
Posted: 25 Jul 2021 13:59
by JezC
@PhilC @exxos I wonder which two forum members might have bought the last two TRUDIE beta boards from Harry then? ;) :roll:
Posted: 25 Jul 2021 15:13
by PhilC
@exxos I was going to make up my own pcb
Posted: 25 Jul 2021 15:16
PhilC wrote: 25 Jul 2021 15:13 @exxos I was going to make up my own pcb
How you going to do that without knowing the schematic, mosfet, resistor values, and led types used.
Posted: 25 Jul 2021 16:49
by PhilC
@exxos I was gonna blag it :lol: You did post a bit about it somewhere.
edit:
Actually for what I want I could simply remove the two LEDs on the Trudie and wire them up. I may put the Led somewhere else other than the keyboard. Not decided yet.
Posted: 25 Jul 2021 21:20
I have found the PCBs and LEDs, but I don't recall which way the LED goes in, so green and yellow may be backwards in which case the LED would have to be swapped around.
I think the yellow is too bright so it may require a resistor change, I just never got around to experimenting with the value IIRC.. and it needs a better method of mounting as it is a bit of a squash underneath the PCB of the keyboard, but again I just did not have time to throw at it all.
Posted: 27 Jul 2021 12:57
@JezC @PhilC Are either of you planning a order any time soon, as I will pop the PCB in the box...
There is actually 4 PCBs on the small panel, so you have to hacksaw them apart.
Posted: 27 Jul 2021 13:14
by PhilC
@exxos probably not for a couple of weeks for me at the mo. So no rush for the PCB but thank you anyway.
