Page 3 of 3
Re: To Buffer or Not to Buffer (TF536)... That is the question.
Posted: 19 Mar 2020 07:41
by terriblefire
8 Bit Dreams wrote: 19 Mar 2020 07:28 Would rather solder 2 ics and 2 caps instread of ordering a separate pcb and populate it, however will be happy to any decision.
Best regards,
-8 Bit Dreams
Its 4 extra ICs, 4 caps, a transistor and 5 resistors to do it properly.
You need to buffer A2-A4, IOR, IOW, IDECS1, IDECS0 as outputs and IDEWAIT and IDEINT as inputs.
Have a look at the A4000 sheets. plus keep in mind that the CPLDs are 3.3v and the signals needed to be put up to 5V.
Its probably worth ensuring that all these are buffered on your board too.
Posted: 19 Mar 2020 10:12
by arkadiusz.makarenko
Personally I can't see reason for it.
Posted: 19 Mar 2020 16:15
by terriblefire
Ok i may have a compromise...
Based on a look at what @8 Bit Dreams had posted i was inspired to try this on for size.. its possible.
Basically the board comes with 3 missing IC's by default and 6 0 0hm resistor networks. If you want the buffer remove the networks and add the IC's... otherwise you can do nothing and have everything as it is now.
This seems to me to be the best compromise?
Posted: 19 Mar 2020 16:51
by 8 Bit Dreams
Mr. Leary, You are pcb's Banksy, because this is an artwork :idea: :idea: :idea: :arrow:
Posted: 19 Mar 2020 23:07
by Danoo
Built in options, engineering ethos raise your hand :thumbup:
Just out of curiosity TF, roughly how many hours does it take to route one of these boards in Eagle (eg. from idea to first revision).
Considering a PCB production unit as an elective next semester. Altium is the design application, I have found that this app has one hell of a learning curve.
Was just wondering what sort of man hours are involved once you have some experience under the belt :?:
Posted: 20 Mar 2020 06:15
by 8 Bit Dreams
From sketch to working board :?:
Steve done TF328 in a weekend :!:
Those was the day's... :P
Posted: 20 Mar 2020 10:45
by terriblefire
Ok..
Ten ordered with the dual buffered/unbuffered option and partial assembly.
Posted: 20 Mar 2020 10:53
by PaulJ_2.0
Nice one, that's a very elegant solution.
Would it be forward of me to reserve one for testing?
Posted: 20 Mar 2020 10:56
by terriblefire
I'll start a new thread. I'm going to build one myself first this time.
Posted: 20 Mar 2020 11:44
by Danoo
8 Bit Dreams wrote: 20 Mar 2020 06:15 From sketch to working board :?:
Thanks for the info,
Wow :shock: that is a short amount of hours to accomplish a working prototype , How much sleep was traded to achieve that outcome?
