Page 3 of 17
Re: 27C400/27C800 EPROM emulator
Posted: 12 Aug 2019 22:04
by terriblefire
Great work. This is what all my Amiga's need.
Posted: 14 Aug 2019 19:53
by GadgetUK164
Looking very cool!!! Super useful if it can be programmed easily enough!
Posted: 18 Aug 2019 15:29
by cmorley
I did a PCB to adapter to an Acorn Master MOS (1Mbit 128Kx8 mask ROM). Just sent the PCB order off.
Master MOS adapter.jpg (133.09 KiB) Viewed 9460 times
Posted: 18 Aug 2019 15:55
by cmorley
Working well in a rev 5 Amiga 500. The data buffers are HCT so 5v CMOS output levels - won't require pull ups like a 27C400 does in a rev 5... The wire goes to the _RESET signal to get ROM swithcing from the keyboard with ctrl+A+A. (ROM switching can also be done via the USB which might be useful for synths, drum machines and other non-computer gear)
Firmware is functional. I have features to add but the core functionality is proven working :D
Posted: 18 Aug 2019 16:51
by PaulJ_2.0
Shut up and take my money!
Posted: 28 Aug 2019 09:43
by JanHolbo
Hi!
Great product in the making!
cmorley wrote: 16 Jul 2019 06:57 I think if TerribleFire and Chucky test then the Amigas are covered.
I know that you seem to have Amigas covered. I would like to help out as well if you need though. I would pay the cost of both kit and P&P to Denmark, if it is not too expensive.
Is it possible to mix rom sizes? 4 x 256K images (1.2, 1.3, DiagRom) and 2 x 512K images (2.04, 3.1.4) ?
Again, great to have people like you and others making new hardware for the machines we grew up with and still love and use :-)
EDIT: I am using an A500 Rev 6a motherboard.
JanHolbo
Posted: 30 Aug 2019 14:59
by cmorley
JanHolbo wrote: 28 Aug 2019 09:43 Is it possible to mix rom sizes? 4 x 256K images (1.2, 1.3, DiagRom) and 2 x 512K images (2.04, 3.1.4) ?
Only with manual switches. You need A17 connected to the Amiga for 512K image but controlled by the switching for a 256KB image.
Chris
Posted: 31 Aug 2019 11:47
by JanHolbo
cmorley wrote: 30 Aug 2019 14:59
Thank you for the answer. Checking on my 2.0 Rom it is a 2.04 (37.175) that does not support IDE boot.
Would putting DiagROM and 1.3 on 512K images together with 2.04 and 3.1.4 (4 x 512K images total) work?
Any preview on price and date of release for either a prototype or RC board?
Jan
Posted: 31 Aug 2019 12:37
by cmorley
JanHolbo wrote: 31 Aug 2019 11:47 Would putting DiagROM and 1.3 on 512K images together with 2.04 and 3.1.4 (4 x 512K images total) work?
Yes that works. I have tried (4 of) 1.2, 1.3, 3.1, 3.1.4 & DiagROM.
If you set the module up as 4x 512KB ROMs and program a 256KB image my firmware programs it twice (so either high/low on A17 is the same ROM image). It also handles byte swapping at program time.
I know there is space in the memory map on an Amiga for an extra ROM but not what you can use that for. In 1MB mode with a flylead from the CPU or Gary you could use this from one module. Is this useful on an A2000 I don't know?
I have a few more of the prototypes. Some are destined for testing in other systems. Terriblefire isn't testing so I sent 2 to Chucky. I don't know how much they will be yet because I am going to get these assembled - batch size and economy of scale will make them cheaper but then I need to pay more money up front and greater risk if there is a fault with them. My aim is that these will be cheaper than the existing multi EPROM/ROM switchers that are for sale now.
Chris
Posted: 06 Sep 2019 10:04
by cmorley
Working in an 8-bit machine. This is an Acorn Master using the ROM emulator/switcher to replace the 128KB MOS mega chip (contains MOS, ROMs & character set). ROM switching working from the BREAK key :)
I will send this off to a friend who uses his Master daily (he did Y2K fixes and assembled MOS images for various versions/configs including a OS 1.20 for better model B compatibility).
