Page 3 of 3
Re: Mega ST - Internal Ultrasatan Bracket (Lotharek)
Posted: 06 Jan 2025 20:31
by macsonny
Yeah, I used the rear port for a customer power connector and HDMI output connector for a RGB2HDMI upgrade. Running out of space!
Anyone know how to thicken the frame on the mount?
Posted: 14 Sep 2026 17:56
by WolfMax
Darklord wrote: 04 Jan 2025 16:38 Hmm, had this lying around on my hard drive...
MegaST_UltraSatan.stl
Hi Darklord
First let me say thankyou for the file. But I have to let you know that it has a couple of issues. I have no experience in 3D printing so sent your file to PCBway to print for me. They got back to me to let me know that the horizontal part of the bracket is not actually connected to the vertical part. However, when I explained I could not fix the file myself, they fixed it for me and sent me the updated file (which I will upload below).
On receiving the printed bracket, the second issue soon came to light. I don't know what model of Ultrasatan the bracket was based on, but my ver 2.1 (purchased from Retro Lemon) forward mounting holes did not line up with the holes in the bracket. The brackets holes were closer to the SD slots approx 5mm from the holes in the Ultrasatan.
I fixed mine by adding some extension pieces and mounting the Ultrasatan using its rear mount holes. This worked perfectly.
So again, thank you for the original file. It was exactly what I needed and gave me a bit of fun making the fix I needed to engineer to make it work for me.
Regards
Colin
Fixed Mega ST UltraSatan rear cover bracket.
(32.89 KiB) Downloaded 18 times
!Message from: Moderator
@WolfMax, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Posted: 14 Sep 2026 18:47
by Darklord
Well, I'm glad it got you where you needed to go and thanks
for uploading a corrected version. :)
Posted: 14 Sep 2026 18:48
by Darklord
Darklord wrote: 14 Sep 2026 18:47 Well, I'm glad it got you where you needed to go and thanks
PS And how about pictures? We *love* pictures! :)
