Page 3 of 13
Re: REV H1 information and interest
Posted: 03 Apr 2019 19:43
by Icky
PhilC wrote: 03 Apr 2019 19:22Is that Mr Ben?
Nope. Close though he is a children's story character. Not a main character though.
Posted: 03 Apr 2019 21:00
by PaulJ
Icky wrote: 03 Apr 2019 19:17
On the other hand if my soldering improves my Caricature would have to be (see if anyone gets the reference):
Hmm.. is that 007 in retirement? :? :? :?
Posted: 02 May 2019 17:11
Tiny update.
This will make more sense when people see was involved with the 16 MHz modification..
Where DE from the GLUE to MMU must be cut and routed to other logic.. So this now has a jumper, to save the track cutting on the next board.
- 1.jpg (49.89 KiB) Viewed 5514 times
- 2.jpg (50.98 KiB) Viewed 5514 times
I have been wondering about trying to integrate the 16 MHz modification onto this revision of the motherboard, but as there is a lot of work yet to do, it would end up delaying this motherboard even further. But whatever modifications are done to the Alpha, they still will be relevant to the H1 board.
The current status of the H1 is basically this..
- H1.jpg (123.54 KiB) Viewed 5514 times
All the modifications which have been done need to be sorted out on the PCB side of things yet.. I will add the simm socket soon.. But I think with so many modifications and additions already done ( There was a lots just fixing all the issues from the Alpha starters, plus the addition of the video DAC, many chips changed, see the start of the post more information about it all) , I think this board should just stop at the state it is in now, otherwise we will just be making far too many changes at once.
It will already take me a while to sort out the PCB side of things without making any further changes to it. I do hope to make a start on this very soon.. Of course it will take a long time before we can consider a run of these boards.. But I'm just letting people know that I'm starting to think about tidying up this board..
I also suggest people check the H1 Schematic and make sure I have implemented all the bug fixes from the alpha correctly..
Posted: 09 May 2019 23:27
Been doing a little bit of tidying up on the schematic and board, I have also added in a total of 4 DIP 68000 sockets which will be basically the expansion sockets.. For example the SEC booster, fast-ram board, IDE can use 3 sockets easily.
I have also started some routing.. I will autoroute the bulk of it, but "sensitive" things like audio & video I always route manually. See my blog for a bit more info on routing progress
https://www.exxosforum.co.uk/forum/viewt ... =70#p21629
I don't think anyone has checked the H1 against the Alpha & mods to make sure I have done them all yet....
Currently, I am waiting for Icky to send me a blank motherboard so I can check proper locations of sockets and holes etc. Hopefully I can get that done over the next couple of weeks.. The PSU holes & floppy holes should be OK as they are, but its best to check against a blank board (with paper print outs) to make sure! I need to add all the screw holes, support post holes etc yet.
If we have good results with the 16MHz mod, I will see if I can work out how to add it onto the H1 (well we on H2 now) but we need to be able to switch back to 8MHz as well. So I think it will be a while before that project is completed.
I will likely not do anymore mods to this MB now (other than swapping to SMT GLUE & MMU, but its un-decided yet see
https://www.exxosforum.co.uk/forum/viewt ... =73&t=1854). with all the patches & mods, plus all the other stuff added, its probably had way to many changes in one go already.
Progress is slow, but its still moving ahead a little at a time. Main hold up currently is the 16MHz mod. So the more people patching the Alpha to try it , the better.
- h2.jpg (240.78 KiB) Viewed 5487 times
Posted: 09 May 2019 23:59
by Icky
exxos wrote: 09 May 2019 23:27
Have started to look at this. Will shout if I see anything. Nothing glaring so far.
No pressure there then :P
Posted: 10 May 2019 08:56
by redhawk668
I've been following this for some time and I would like to contribute to this project too, so could you put me on the list for one board?
Posted: 10 May 2019 09:43
redhawk668 wrote: 10 May 2019 08:56
Sure, added :)
Posted: 21 May 2019 23:20
by Anzac
I can support this too... can't solder, so, just support
Just out of curiosity, could the extended joystick ports be added?
Posted: 21 May 2019 23:41
The ST chip set doesn't support the extended ports...
Posted: 22 May 2019 05:51
by Anzac
So, how can I support the project?
