Page 3 of 18
Re: Latest TF534 is here
Posted: 23 Jan 2019 09:54
by go0se
terriblefire wrote: 23 Jan 2019 09:10 Not sure. Doesn’t manage to read the first 4 words in rom correctly. So might be a solder issue
As a great man once said : "Clocks are the biggest problem for a non booting Diagrom, or just bad soldering."
S.J Leary, Youtube, December 2017 :)
Posted: 23 Jan 2019 18:44
by terriblefire
This usually applies to board that has booted at least once... no such luck here.
Posted: 24 Jan 2019 12:17
by terriblefire
ok it boots to DiagROM. Bad firmware was the issue.
Posted: 24 Jan 2019 12:23
by kludge
terriblefire wrote: 24 Jan 2019 12:17 ok it boots to DiagROM. Bad firmware was the issue.
Great stuff! Looking forward to the next live stream!
Posted: 24 Jan 2019 20:51
by Homer79
If you want a fan holder, how about something like this? maybe locate the holes with maximum clearances available
if its too tall then maybe a 5015 blower fan off to the side
https://www.ebay.co.uk/itm/2Pcs-38mm-x- ... ctupt=true
https://www.ebay.co.uk/itm/5V-DuPont-35 ... ctupt=true
tf534 fan.jpg (37.15 KiB) Viewed 5290 times
!Message from: Moderator
@Homer79, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
Posted: 24 Jan 2019 22:15
by terriblefire
Thanks. Is there any clamps that are suitable available off the shelf? I just try to make it easy whereever i can.
Also I broke the TF534.. well the IDE... no idea what i did.
Posted: 24 Jan 2019 22:59
by kludge
terriblefire wrote: 24 Jan 2019 22:15 Also I broke the TF534.. well the IDE... no idea what i did.
You mean that you have no IDEa? Sorry.
Posted: 25 Jan 2019 16:34
by MarkFixesStuff
kludge wrote: 24 Jan 2019 22:59 You mean that you have no IDEa? Sorry.
:bravo: :lol:
Posted: 27 Jan 2019 08:53
by terriblefire
So it turns out that the problem was a duff IDE cable. Probably caused by me using it as a jig while soldering.
Posted: 27 Jan 2019 10:59
by kludge
So... It sounds like this will be released soon-ish. If I wanded to begin the hunt for components for the TF534; what are the specs for the CPLDs and RAM?
