Page 20 of 21
Re: TF4060 Beta Program
Posted: 22 Sep 2025 13:19
by TheoTheoderich
What IDE do you mean?
The internal IDE of the A4000T is working fine. Makes no difference if with TF4060 installed or not.
I am also using a Buddha Plus One and its IDE is also working fine.
Posted: 22 Sep 2025 15:03
by terriblefire
Where you ever, with any fw, able to see a disk in the TF IDE.
Posted: 25 Sep 2025 16:13
by swinterstein
Hi all,
I'm a proud new owner of a TF4060 with a 68060 Rev6 CPU. However, getting it to work in my A3000 didn't go as smoothly as I would have liked..
I learned rule #1 the hard way: Always make sure that a CPU board in the A3000 is pressed down really, really, REALLY hard into the slot!
Also, I had to fight with the Amiga filesystem getting corrupt on my ZuluSCSI, which caused all sorts of trouble (e.g. WHDLoad would start, but lock up immediately). I don't know if that can be caused by a flakey CPU connection, but those where my whoes..
My current state is that the system is working at 50 MHz - after some weeks of on and off work.
For now, I have some questions:
- What is the meaning of the color bars after a cold startup - is that the TF4060 initializing itself successfully? While getting the card to work, I had white "snowflakes" on a grey background occasionally for a fraction of a second - is that a failure state of the board?
- I'm running under AmigaOS ROM 3.1.4. Sysinfo shows that all Libraries are residing in the card's address space starting at $08000000 so the ROM seems to be remapped/copied. That seems to happen automatically?
- Strangely enough, Sysinfo shows that dos.library is version 40.5 (e.g. KS 3.0), where it should be 46.x (like the other libraries from 3.1.4 ROM). I haven't tested without the TF4060, but could that in any way be related to the cards initialisation?
From Germany,
-Stefan
Posted: 25 Sep 2025 16:52
by terriblefire
swinterstein wrote: 25 Sep 2025 16:13 For now, I have some questions:
The colourbars are an amiga tradition for 060 accelerators. They show that the code to disable the FPU before exec starts has been run. Nothing more.
I dont understand this question. The rom modules get loaded in to ram because its expontentially faster than using it from rom. Is there a TF4060 question here? This question should really be directed at the AmigaOS developers.
Again this is not a TF related question. Ask the AmigaOS developers.
EDIT: I cannot support random question about AmigaOS. Sounds like your TF4060 is working as designed. There is no software in the TF except cpuspeed and ehide.device.
Posted: 27 Sep 2025 10:43
by TheoTheoderich
terriblefire wrote: 22 Sep 2025 15:03 Where you ever, with any fw, able to see a disk in the TF IDE.
Please excuse the late reply.
Yes, all CF cards or IDE hard drives that I connected to the TF were displayed in HDToolbox and I was able to format them correctly (using OS 3.2.x), but strange graphics errors occurred at low resolutions and the IDE often/randomly stopped working after read accesses.
When nothing is connected to the ehide.device, the card works perfectly.
Posted: 29 Sep 2025 12:31
by terriblefire
Ok so there is something bad up with my 4KT
Posted: 29 Sep 2025 17:43
by swinterstein
terriblefire wrote: 25 Sep 2025 16:52 Sounds like your TF4060 is working as designed. There is no software in the TF except cpuspeed and ehide.device.
Thanks, that helps. Maybe my wording was a bit sloppy, but I also wanted to share my experiences with others.
terriblefire wrote: 25 Sep 2025 16:52 I cannot support random question about AmigaOS.
You don't have to.
Posted: 07 Mar 2026 16:17
by terriblefire
I've working on this more or less constantly for years now. its not that i cant get any single feature. its that the 4000 and ESPECIALLY the 3000 is so complicated that when i change something it breaks something else for 50% of the users.
Taken a short break on this to see if I can come back a the problem from another angle.
Posted: 14 Mar 2026 07:54
by fidelware
Which IDE port do you use, the one on the graphics card or the one on the motherboard? Can both be used simultaneously to have multiple hard drives?
Posted: 14 Mar 2026 10:33
by terriblefire
fidelware wrote: 14 Mar 2026 07:54 Which IDE port do you use, the one on the graphics card or the one on the motherboard? Can both be used simultaneously to have multiple hard drives?
Yes (you can use both) they are separate IDE chains. The TF-IDE is faster (uses ehide.device, which is in the TF card) and it should run 2 drives. I dont test this setup often but i know ehide scans for it
