Page 19 of 28
Posted: 19 Jun 2023 08:47
That doesn't seem to happen. All that happens when I press reset is it seems to screw up the com port and I have to unplug the usb and restart the program. If I press esc I get the HDC prompt . So it's not like comms isn't working.
Posted: 19 Jun 2023 09:43
by dad664npc
okay so if you see the prompt type status
Posted: 19 Jun 2023 11:00
dad664npc wrote: 19 Jun 2023 09:43
So the one in my test board is
BBaN RPP HDC
ATARI ACSI HDC Emulator
Build date May 18 2023 12:56:45
Release 1.01
Steve Bradford aka cryptodad
CONTROLLER ID: 0
sd0: unmounted - command packets 0
sd1: unmounted - command packets 0
We have been running for 0 days 00:00:16
CPU clock is running at 150 MHz
SPI clock is running at 4294 MHz
So need to download all the files you sent and see which one that version is then.
Found that version and flashed in one of the new boards. Now it boots right up with HD11, though the write problems are still there :(
When trying to delete files from C: it does this..
CMD_READ tgt=0 lun=0 (0x08:00:a5:28:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:38:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:48:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:58:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:68:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:78:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:88:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:98:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a4:48:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a5:a8:08:00) (00)
TEST_UNIT_READY tgt=0 lun=0 (0x00:00:00:00:00:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:a6:98:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ab:68:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ab:b8:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ac:28:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ac:38:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ac:68:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:ac:98:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:9b:a8:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:8a:88:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:01:88:08:00) (00)
CMD_READ tgt=0 lun=0 (0x08:00:00:b8:08:00) (00)
Then just pops up the usual error box on the desktop.
Posted: 19 Jun 2023 13:31
by Badwolf
exxos wrote: 19 Jun 2023 11:00
Just out of interest (there are no CMD_WRITEs there), if you hit ESC to refresh the window, or reset the machine at this point, do you see a CMD_WRITE log message appear before the next command that works?
I've a theory something hangs before or during the write starts up on my one which stops the log flushing for whatever reason.
Posted: 19 Jun 2023 13:49
Badwolf wrote: 19 Jun 2023 13:31
Not sure, it's "off my desk" now as the DFB1's have arrived. So I can't do any testing currently now.
But indeed I never saw any writes in the log during all the "hangs".
Posted: 19 Jun 2023 16:04
by DaveC
Well the new firmware seems to work fine here with my STe, so that's me happy!
Posted: 19 Jun 2023 16:15
by chronicthehedgehog
DaveC wrote: 19 Jun 2023 16:04
Me too. I've been doing quite a bit of experimenting with partitioning and installing the likes of Neodesk etc and it feels really solid.
Posted: 19 Jun 2023 17:39
by dad664npc
The debug prints are handled by CPU0 - occasionally a print will be missed because CPU0 loop is checking to see if a key has been pressed and if micro-sd cards have been inserted/removed
Posted: 19 Jun 2023 22:53
by Badwolf
Just to confirm, I've quickly got my STFM mobo up and running and the open-source branch from Jan '21 with my minor mods for my board design faux pas does indeed work. Including write. I've not tried the latest commercial firmware yet, but I suspect that will if this does.
Ruddy 'bad' STE DMA strikes again! :)
Posted: 30 Jun 2023 14:26
by JezC
@exxos Any idea if/when you might have more of these available in your store?
