Page 19 of 97
Re: ST536 STE EDITION
Posted: 15 Mar 2025 15:17
coonsgm wrote: 15 Mar 2025 15:10 Yeah, this is the same CF card I've been using with the STE536 for the last 6 months or so running the modded 206 for that time. It isn't byteswapped.
My only suggestion is to try the other 2 firmware as they run the CPU at 8mhz and see if IDE behaves then..
Posted: 15 Mar 2025 15:18
by coonsgm
Trying a different CF card now...if that doesn't work I'll try the other firmware
Posted: 15 Mar 2025 16:27
coonsgm wrote: 15 Mar 2025 15:18 Trying a different CF card now...if that doesn't work I'll try the other firmware
Might also be an idea to show how you fitted the patch board.. it's odd as @Steve and @Badwolf seem to be stable now but not you :shrug: by the sounds of it, the changes didn't help at all ? So can only assume you have a different issue :shrug:
Posted: 15 Mar 2025 16:49
by Steve
So BW is stable now? What did he do?
Posted: 15 Mar 2025 16:52
Steve wrote: 15 Mar 2025 16:49 So BW is stable now? What did he do?
Same as you..
Posted: 15 Mar 2025 17:08
by coonsgm
exxos wrote: 15 Mar 2025 16:27
Here's a photo of the patch board.
by Steve
exxos wrote: 15 Mar 2025 16:52
Same as you..
Ah I suppose that means removing the cap and osc. Because last I knew he'd installed the board, but was unstable.
Posted: 15 Mar 2025 17:10
coonsgm wrote: 15 Mar 2025 17:08 Here's a photo of the patch board. IMG_2762.jpg
Seems fine...
Posted: 15 Mar 2025 17:16
Steve wrote: 15 Mar 2025 17:08 Ah I suppose that means removing the cap and osc. Because last I knew he'd installed the board, but was unstable.
It was unstable, then he removed the cap and was fine...
My concern is , why is the timing so sensitive to start with... If I go back to the original TF536 timings, TTram doesn't work at all... Even on the ST536..
My only idea at this point would be to move to a 288xl PLD as I can only think some timings off due to the compiler struggling to fit the code in a 144.
Posted: 15 Mar 2025 17:22
by coonsgm
@Steve Which cap did you remove? I assume the oscillator is the one closest to the patch board.
