Page 19 of 23
Re: TF536 Rev 2 Design Complete (all gone)
Posted: 09 May 2020 12:01
by LADmachining
Well, I don't have a spare CPLD, as my one had the same bad packaging you had and all of the corner pins are bent. :x
Posted: 09 May 2020 12:04
by terriblefire
LADmachining wrote: 09 May 2020 12:01 Well, I don't have a spare CPLD, as my one had the same bad packaging you had and all of the corner pins are bent. :x
Did you get a refund from RS?
Posted: 09 May 2020 12:29
by LADmachining
terriblefire wrote: 09 May 2020 12:04
Will have to contact them Monday, hopefully they can send me another.
Posted: 09 May 2020 12:38
by terriblefire
LADmachining wrote: 09 May 2020 12:29
You can do it automatically via the web interface.. Just go to returns.
Posted: 09 May 2020 15:09
by terriblefire
Has anyone tested the rev2 in an ST?
I've just tried my rev 1 and rev 2 with identical firmware code and the rev 1 is fine and the rev 2 sulks...
Posted: 09 May 2020 15:19
by PhilC
terriblefire wrote: 09 May 2020 15:09 Has anyone tested the rev2 in an ST?
I've had my Rev 2 running TOS 2.06 but its a bit hit and miss, I get 8 bombs sometimes and boots the next.
I've got as far as running Gembench with it a few times (slow results as the firmware wants tweaking as you know)
Posted: 09 May 2020 15:56
by PhilC
Managed to burn the latest EmuTos to rom and it boots to desktop fine with that.
I'm using one of exxos's ide boards as the rom decocder tho, so not tested the ide interfaceon
Edit:
won't run Gembench though as I get kernel errors etc and of course this IDE board is probably confusing the hell out of it.
Posted: 09 May 2020 16:34
by terriblefire
PhilC wrote: 09 May 2020 15:56 Managed to burn the latest EmuTos to rom and it boots to desktop fine with that.
Edit:
I'm struggling to get this ST to work at all to be fair... :/
Posted: 09 May 2020 17:15
by PhilC
terriblefire wrote: 09 May 2020 16:34
I'll try and plug it into an original ST and see how it goes
Posted: 09 May 2020 17:19
by terriblefire
PhilC wrote: 09 May 2020 17:15 I'll try and plug it into an original ST and see how it goes
I've got an ST firmware if you want to test it
