Page 18 of 19
Posted: 16 Oct 2026 16:29
by alexh
exxos wrote: 16 Oct 2026 15:44 There is supposed to be a 5V USB power on the connector
5V USB? You mean "+5VSB"? 5 volt standby power? Why would anything on CT6x be wired to "+5VSB"?
Posted: 16 Oct 2026 16:32
alexh wrote: 16 Oct 2026 16:29 5V USB? You mean "+5VSB"? 5 volt standby power? Why would anything on CT6x be wired to "+5VSB"?
Id assume that's how the CT60 turns on / off the PSU.. It would need power to do that in the first place. Those 2 chips must be the circuit which controls that.
Posted: 16 Oct 2026 16:47
by alexh
Ah probably to do with full ATX spec when you can turn an ATX PSU off(/on?) with software? Not applicable if you're using a physical switch like CT60PSU I guess.
Posted: 16 Oct 2026 16:52
alexh wrote: 16 Oct 2026 16:47 Ah probably to do with full ATX spec when you can turn an ATX PSU on/off with software? Not applicable if you're using a physical switch like CT60PSU I guess.
No idea if software can turn it on/off or not. Maybe it could turn it off via software, never heard of anyone doing that though. I just always used the power headers on the CT60 to turn the PSU on. Likely some people just hardwire the PON wire so as soon as the PSU is turned on, the CT60 powers up..
Posted: 16 Oct 2026 18:25
by alexh
exxos wrote: 16 Oct 2026 16:52 No idea if software can turn it on/off or not. Maybe it could turn it off via software, never heard of anyone doing that though.
Well that is how PC's turn off ATX PSUs without any button presses.
exxos wrote: 16 Oct 2026 16:52I just always used the power headers on the CT60 to turn the PSU on.
I understand. Again that is how most PCs turn on ATX PSUs they have a momentary PON button going to the motherboard. I didn't realise there were any electronics associated with it on the motherboard powered on +5VSB! I thought the button press just went directly to the PSU. Learn something new every day.
Posted: 16 Oct 2026 23:10
by Maximilian
exxos wrote: 13 Oct 2026 14:26 Must have "blown" £100 on ROM's so far :roll:
Maybe you can make a bodge to use a onerom for this?
Posted: 17 Oct 2026 17:37
Maximilian wrote: 16 Oct 2026 23:10 Maybe you can make a bodge to use a onerom for this?
Had not heard about that project. I cut down flashy clock for a STE version, could be adapted for the falcon.. Just not enough time for all the piles of side projects I want to do :(
Posted: 29 Oct 2026 18:33
Anyway, Ordered some -7ns PLD's a few days ago. Hopefully they will actually work! Just got a £60 bill from DHL for import tax :roll: I believe the replacement Videl is on order as well now.
Probably not much can be done until parts arrive. But I am really busy with work next week or 3, so likely not much time for any Atari stuff anyway.
Posted: 30 Oct 2026 03:30
by HigashiJun
exxos wrote: 29 Oct 2026 18:33 Just got a £60 bill from DHL for import tax :roll:
Isn't that too much for just a few PLDs ?
Posted: 30 Oct 2026 07:56
HigashiJun wrote: 30 Oct 2026 03:30 Isn't that too much for just a few PLDs ?
Its always to much. They expensive parts to buy these days. But they also charge on shipping as well.. Really sucks :(
