Page 18 of 70
Posted: 01 Sep 2018 10:34
Smonson wrote: 01 Sep 2018 08:52 I can't guarantee that the buffer will be fast enough for the 32MHz clock though, I recommend checking it on a scope before depending on it.
OK, what chip did you use ?
Posted: 01 Sep 2018 10:52
by Smonson
exxos wrote: 01 Sep 2018 10:34 OK, what chip did you use ?
74LVC245A
https://assets.nexperia.com/documents/d ... CH245A.pdf
Posted: 02 Sep 2018 15:41
by poobah
Smonson wrote: 01 Sep 2018 10:52
74LVC245A
Have you guys looked at the IDT QuickSwitch devices?
Posted: 02 Sep 2018 16:20
poobah wrote: 02 Sep 2018 15:41 Have you guys looked at the IDT QuickSwitch devices?
I'm using them :)
Posted: 02 Sep 2018 16:37
by troed
74LVC245A
Seems plenty fast according to that spec sheet, unless I'm misunderstanding something.
Posted: 02 Sep 2018 16:57
troed wrote: 02 Sep 2018 16:37 Seems plenty fast according to that spec sheet, unless I'm misunderstanding something.
I think it was just a suggestion..Nothing wrong with those of course.
For my stuff, I am pushing every MHz out of everything, so the IDT switches have pretty much zero delay, which is what I need. In case of the FPGA stuff, a few ns isn't going to make any odds. Though I guess the IDT stuff may be easier to solder as they (IIRC) are larger packages.
Posted: 02 Sep 2018 20:18
by poobah
exxos wrote: 02 Sep 2018 16:57 ... Though I guess the IDT stuff may be easier to solder as they (IIRC) are larger packages.
Yup, I solder them by hand fairly easily.
Posted: 03 Sep 2018 00:30
by Smonson
The only reason I mention the buffer is that the one I used for the 16MHz line (M74VHC1GT125DF2G) can't hack it at 32MHz. Since 16MHz is not too fast by today's standards I didn't worry about it when selecting buffers.
Posted: 03 Sep 2018 01:01
by rpineau
May I suggest the NB3N551 for clock buffering :
https://www.mouser.com/datasheet/2/308/ ... -83648.pdf
Posted: 03 Sep 2018 01:15
by Smonson
Suggestions are welcome. But from the datasheet it looks like this device is only guaranteeing to produce a 2.4v high. Dunno if the Atari would be too happy with that.
But this is definitely the kind of thing I should have used in the first place
