Page 18 of 23
Re: TF536 Rev 2 Design Complete (all gone)
Posted: 08 May 2020 15:20
by LADmachining
No solder whiskers between any pads?
Posted: 08 May 2020 17:06
by terriblefire
Subzero79 wrote: 08 May 2020 14:11 Beetween gng and 3.3 volts i measure 1.1 ohm is normal
Removed all ics exept cpld and measures 1 ohm or is board defect?
Unsolder all parts pcb defective short beetween gnd and 3.3
@ terriblefire need a new one
I'll send you one when i the bulk order arrives. I've never seen a dead short like that from JLCPCB they test them before they get sent out.
Posted: 08 May 2020 18:42
by Subzero79
One plus one i want to buy
Posted: 08 May 2020 21:59
by terriblefire
Subzero79 wrote: 08 May 2020 18:42 One plus one i want to buy
you tried putting 12V on the 3.3v line with all components removed and see if it burns away?
Posted: 09 May 2020 02:40
by Subzero79
I will
Posted: 09 May 2020 09:43
by terriblefire
@LADmachining did you get anywhere with testing
Posted: 09 May 2020 10:24
by LADmachining
Subzero79 wrote: 09 May 2020 02:40I will
Are you sure you want to do that? Check his username! ;)
Posted: 09 May 2020 10:26
by terriblefire
LADmachining wrote: 09 May 2020 10:24
You will have a brief terriblefire. Then it should clear the short.
My H6632B is good for this. When that runs out of amps i use a car battery.
@Subzero79 if you get photos of the defect for me i'll be able to get a refund from JLCPCB.
Posted: 09 May 2020 10:30
by LADmachining
terriblefire wrote: 09 May 2020 09:43 @LADmachining did you get anywhere with testing
I have not yet found any open or short circuits on the board.
The last thing I can think is that I have somehow killed the CPLD. It was bought from RS, and soldered at a grounded workstation, so not sure what is going on. I have another new spare, so I could try swapping them over.
Apologies for holding up progress on the TF536, I am struggling to find much free time to get into the workshop.
Anthony
Posted: 09 May 2020 10:32
by terriblefire
LADmachining wrote: 09 May 2020 10:30
Apologies for holding up progress on this, I am struggling to find much free time to get into the workshop.
Anthony
No worries. I'm hovering over the trigger button on a 150 pc order so i'm keen to figure out issues before i do.
