Page 159 of 339
Posted: 11 Oct 2021 16:00
They don't give you much bodgeroom space on these boards :roll:
So the ripple is about 10mV now pretty impressive!
Spikes are not actually noise on the circuit, up interference somewhere else in my room. It is almost impossible to do these measurements accurately unless you're in a totally "silent" room.
This is with the power supply turned off for example..
Probably needs a little bit more capacitance on the output but overall this chip looked pretty impressive so far!
Posted: 11 Oct 2021 17:39
Does anyone know why this consistently happens in every corner ?
Posted: 11 Oct 2021 17:43
by PhilC
Belt too tight pulling it off course as it slows down?
Posted: 11 Oct 2021 18:29
PhilC wrote: 11 Oct 2021 17:43 Belt too tight pulling it off course as it slows down?
Will slack off X as see if anything changes..
Posted: 11 Oct 2021 18:41
exxos wrote: 11 Oct 2021 18:29
Nope, X & Y pretty loose now and still exactly the same..
Oddly tightening up the X now seems to be creating gaps in between each pass now :roll: I guess I will have to go recalibrate it again :roll:
Posted: 11 Oct 2021 19:22
by PhilC
@exxos ok, another look. It looks to be showing down extrusion at the end of the runs before it changes direction. There is a setting where you can stop extrusion early, not that I can remember what or where it is
Posted: 11 Oct 2021 19:28
PhilC wrote: 11 Oct 2021 19:22 @exxos ok, another look. It looks to be showing down extrusion at the end of the runs before it changes direction. There is a setting where you can stop extrusion early, not that I can remember what or where it is
There is, but its all turned off.
Saying that try "extra restart" distance see that does anything.
Posted: 11 Oct 2021 19:39
0.4mm extra restart seems to solve the problem, but gives a little blob..
Trying 0.2mm now..
That little blob is almost completely gone and there is like there was before on the corners.. Odd..
Posted: 11 Oct 2021 22:05
So this has also been driving me nuts...
When it does that diagonal infill is to put twice as much down as it is supposed to. The perimeter overlap is only set at 8%, and I am actually starting to get gaps. I do not think this is actually infill as such because altering the percentage or width with does not ever change anything on this first layer.
Posted: 12 Oct 2021 16:09
After much more messing about the gap which was shown in this post Seem to be down to a new feature I just found "linear advance". By default my printer was set at 0.2. So I tried it at 0.1 and those gaps disappeared. I have since lowered it to 0.04.
I have also lowered the extrusion rate down to 93%. Despite everything been calibrated properly, I really question if the software is processing these values correctly.
