Posted: 26 Apr 2026 14:23
yes, mainly smaller things;
- usb keyb/mouse
- sotware controlled volume for the ym output
- small amp and header for internal speaker
(mute control is Falcon compatible)
- ide port is now big endian
- pwm fan control
- argb lighting header
- and misc other minor things
The biggest change and what takes most space is the added DSP, and the RAM for it.
Which is not mandatory and the computer should work fine without it soldered.
For now, I've routed its two ESSI ports to one internal header each
That part is not set in stone but I don't know exactly what I want to do with them so this would provide an easy way to experiment.
One ESSI could for example be an I2S audio in+out, or provide three individual SPI ports.
Or something else entierly but realistically that's probably how you'd want to use them.
If I were to 'hardwire' it I on the board I would probably do something like that:
One SPI controlled codec for audi in + out, and then two SPI headers for playing around with random SPI modules (wifi perhaps?)
OpenOCD has support for its Jtag/OnCE debugger interface so that's on a header too.
- usb keyb/mouse
- pwm fan control
