Page 16 of 48
Re: BLITTER RE-CREATION THOUGHTS
Posted: 17 Apr 2019 23:52
by rpineau
That's one good looking board !
Posted: 18 Apr 2019 08:05
by PhilC
Icky if you share it as a PDF we can cut it out and try it for size on other revision boards if youd like,?
Posted: 18 Apr 2019 11:56
by Icky
PhilC wrote: 18 Apr 2019 08:05
Stop with the ideas PhilC. Now I have a project to create a PDF :)
Posted: 18 Apr 2019 11:58
by PhilC
Just stick the board onto a scanner if you've got one?
Besides, you've got 4 days of fulfilling those ideas and lots of label printing.
Posted: 18 Apr 2019 12:00
by PhilC
Or post me a spare board if you want and I'll do it for you?
Posted: 18 Apr 2019 12:09
by dhedberg
Should be able to produce a PDF based on the gerber files.
Posted: 18 Apr 2019 12:57
It doesn't actually matter at this point what the board fits and what it does not, as this is only a development board more than anything. Icky did do some research into this before designing the board. But only the PCB is done, nothing else, so it's a long way off being actually a working product.
Posted: 18 Apr 2019 13:09
by Cyprian
Icky wrote: 17 Apr 2019 23:25
The photo doesn't do it justice as my camera was shading the board when I took it.
Well at least my first test of the board works i.e. does it fit in the ST without it hitting the shielding at the sides
need one!
Posted: 18 Apr 2019 13:18
Cyprian wrote: 18 Apr 2019 13:09
need one!
You know the proper blitters are in my store now ? The FPGA board is likely going to cost a lot more than the proper chips.
Posted: 18 Apr 2019 13:54
by Icky
exxos wrote: 18 Apr 2019 13:18
need one!
Indeed - I can only echo exxos. This is in no way a product yet. We haven't even built this first board. Even when we do we need to see if the core will actually work on the FPGA and there is probably going to be a towered board on there somewhere to patch etc, etc, etc.
Anyone needing a Blitter I would recommend getting one from exxos' store as these I think are probably the last batch around out there. Once they are gone they are gone.
