Page 16 of 22
Re: Mega ST project
Posted: 18 Dec 2021 02:42
by HigashiJun
Quick edit:
MC68HC000 CPU also runs fine (PAK mode and fallback mode).
Something was probably connected wrong yesterday...
Re: Mega ST project
Posted: 18 Dec 2021 10:40
by HigashiJun
frank.lukas wrote: 14 Dec 2021 13:37
The relocator pcb and the pak can be the problem. I have a extension for the mega st bus connector to test it ...
Hello Frank,
I have tried your VOFA adapter (so no CPU relocator, as the PAK and VOFA can fit without any problem) with my PAK68 and the result is the same. I have a freeze when the VGA driver starts to load (Idek driver and NVDI 5.03).
I have also tried the STGA30 driver, but I have a freeze.
So the CPU relocator is not the problem here.
Re: Mega ST project
Posted: 18 Dec 2021 21:58
by frank.lukas
What pullups have you on the board?
Re: Mega ST project
Posted: 18 Dec 2021 22:11
by HigashiJun
frank.lukas wrote: 18 Dec 2021 21:58
If you mean the bus resistors on the motherboard, they are as per Exxos' recommendation, i.e. address bus and data bus are 2.2k Ohm.
Re: Mega ST project
Posted: 19 Dec 2021 07:12
by HigashiJun
Ok , I have sorted all issues out.
The FDD now works fine. I was fiddling with PAK68 jumpers settings and I realized jumper J9 was set to synchronous clock...
Once set to asynchronous, everything started to work as expected, but not at 50 Mhz... :(
The Mega ST starts to boot at 50 Mhz but then freezes with 4 bombs after an error free memory check.
So I have (for the moment ?) to go with 32 Mhz.
I will buy a 40 Mhz oscillator and check if I have more success than with 50 Mhz.
What is strange is that CENTBENCH sometimes shows the right CPU speed, i.e. 32 Mhz and sometimes dispalys a wrong value, like 19 Mhz...
The FPU speed is always accurate.
Re: Mega ST project
Posted: 19 Dec 2021 09:12
by HigashiJun
EDIT: I managed to run the Mega ST at 50 Mhz, but without the HDD.
Booted normally, but I had corrupted TOS menus.
Re: Mega ST project
Posted: 20 Dec 2021 11:37
by HigashiJun
I finally have a better view of what would my Mega ST look like when this project is finished.
- MegaST.jpeg (408.2 KiB) Viewed 2809 times
There are still some issues to overcome, but if everything comes together, it should be the final version.
I am still hesitating concerning the CD-ROM drive, but hey, we are in 2022 soon and the already existing USB solution is very useful...
As the CPU relocator works reliably with the 68HC000 only, I am waiting for a 4 layer PCB relocator. It is actually in production at JLCPCB and should be delivered soon.
The current IDE ribbon might be replaced by the following IDE-CF adapter:
- IDECF.jpg (28.09 KiB) Viewed 2809 times
The other things to do are:
- Think where to fit the USB ports
- Think where to fit the Tweety Board connector (I already have an idea)
- Think whether to add a 68000/68030 switch for the PAK68 fallback mode
- Find a place to fit the LED from the Lightning ST
And that should be all...
Re: Mega ST project
Posted: 20 Dec 2021 13:00
Wow, that's jam packed!! Nice one.
Re: Mega ST project
Posted: 20 Dec 2021 22:19
by HigashiJun
rubber_jonnie wrote: 20 Dec 2021 13:00
Thank you !
Yeah, a sandwich in a pizza box.
:D
Re: Mega ST project
Posted: 21 Dec 2021 03:17
by Darklord
Congratulations on getting your "mega" project to this point. :)
I put the USB ports in the expansion cover on the back of the
Mega ST for my Lightning ST setup. Dead handy.
I suppose it would be much more convenient and accessible
if one could have them in the front casing but I was afraid
that I would mar the looks of my machine...
- Mega ST4-Lighnting ST01.JPG (121.62 KiB) Viewed 2746 times
