Page 15 of 16
Re: Something experimental - A5000 mouse ball replacement.
Posted: 25 Jul 2024 11:52
stephen_usher wrote: 25 Jul 2024 11:40 Is there any way that you can put the resin into a syringe and inject it from the base of the mould so that you don't risk getting the filler hole blocked by a bubble?
Oddly when I just used resin it came out fine, however I think the addition of the iron powder has clearly changed the viscosity leading to the bubble.
Injecting the material is something I'm seriously considering for the next run.
I've also just ordered a new seamless 20mm mould and I found some 20mm seamless black rubber balls on AliExpress that I thought I'd try too.
Posted: 25 Jul 2024 12:19
by HigashiJun
Next try should be good.
8-)
Posted: 25 Jul 2024 13:38
HigashiJun wrote: 25 Jul 2024 12:19 Next try should be good.
8-)
Fingers crossed
Posted: 25 Jul 2024 16:18
by alexh
I wonder if something as simple as putting the mold on your mobile phone when it is on vibrate would be enough to get the air bubbles to the top or if you will need a more powerful vibrator (oo'er)
Posted: 25 Jul 2024 16:34
alexh wrote: 25 Jul 2024 16:18 I wonder if something as simple as putting the mold on your mobile phone when it is on vibrate would be enough to get the air bubbles to the top or if you will need a more powerful vibrator (oo'er)
That's another thought I'd had too, can I use something to help vibrate out the bubbles, and I have a stack of old mobiles :)
Posted: 02 Aug 2024 14:19
Well, I thought this was it:
They are hard black seamless, so smooth, rubber balls, 20mm. They fit perfectly, trouble is, they jam up. I have tried cleaning them, but they just won't play nicely.
Dammit...
Posted: 02 Aug 2024 14:32
by stephen_usher
Probably too grippy.
Spray one with gloss paint? Or maybe satin actually.
Posted: 02 Aug 2024 14:54
stephen_usher wrote: 02 Aug 2024 14:32 Probably too grippy.
It is indeed too grippy, just considering my options.
Posted: 02 Aug 2024 16:06
by peters
Would a nylon ball bearing be too light ?
https://simplybearings.co.uk/shop/p6120 ... _info.html
Posted: 02 Aug 2024 16:18
peters wrote: 02 Aug 2024 16:06 Would a nylon ball bearing be too light ?
I'll check the weight, I have an idea where it's supposed to be, but I have tried a Delrin ball and that was too light.
