Page 139 of 215
Re: Stuff and Things.
Posted: 08 Feb 2024 09:39
Just for fun I decided to hook up the TRS-80 to the micro TV and make sure I could get a steady signal, and this is the result:
- PXL_20240208_091507501.jpg (256.85 KiB) Viewed 1405 times
It's really quite a nice little TV overall :)
Posted: 08 Feb 2024 10:45
by stephen_usher
:dualthumbup:
I was thinking that you could probably do with a little composite video green screen monitor, but then saw how much people are trying to sell them for on eBay.... GULP!
Posted: 08 Feb 2024 11:18
stephen_usher wrote: 08 Feb 2024 10:45
:dualthumbup:
Which is precisely how I ended up with this little fella.
Posted: 08 Feb 2024 16:23
by JezC
:dualthumbup:
I think I still have the Philips BM7502 green screen monitor I bought to use with my BBC model B...that supports composite video iirc.
Note to self: Must recap the Beebs plus accessories and test them sometime this year... :roll:
Posted: 08 Feb 2024 17:09
JezC wrote: 08 Feb 2024 16:23
:dualthumbup:
Are you trying to sell it to me....?
Posted: 08 Feb 2024 22:05
by JezC
rubber_jonnie wrote: 08 Feb 2024 17:09
Perish the thought...I've owned it from new (since the mid-80s) and once I refurb it 9and the Beebs) it will probably be the main display for them until I sort out some VGA-style solution or fix my Cub monitor...
Posted: 08 Feb 2024 23:56
JezC wrote: 08 Feb 2024 22:05
Just checking....
Posted: 10 Feb 2024 20:16
Well that was disappointing. My 2012 Macbook Pro has died, the keyboard input is mullered even with an external keyboard.
Not happy with that at all, so my Dell XPS has now been pressed into service.
Turns out it was also the source of my 50Hz hum on the scopes...
Posted: 10 Feb 2024 21:36
by stephen_usher
Probably the USB interface died on the MacBook Pro. :(
Posted: 11 Feb 2024 09:32
stephen_usher wrote: 10 Feb 2024 21:36
My thoughts as well. It might be repairable, but getting the parts is the problem, and a donor board may well have the same issue. If I can find schematics I might be able to ID the part, otherwise it's toast, at least from my perspective.
