Yesterday was re-cap the Saturn day, and what a lot of caps it was!!
The machine itself is really quite easy to dismantle, so getting the stage of 'a pile of Saturn' didn't take long:
- PXL_20231028_110444909.jpg (414.47 KiB) Viewed 1229 times
First up for recap was the CD unit:
- PXL_20231028_114035395.jpg (244.28 KiB) Viewed 1229 times
Removal is quite simple, the unit lifts out as soon as the top of the Saturn comes off, and there are just two cables to unplug and one earth strap that's screwed to a central point and joins the mainboard GND to the CD drive GND.
The biggest problem with the CD board is that the CD drive motor needs to be desoldered from the board to separate the laser assembly from the PCB. You could in theory replace the caps without separating the two, but it would risk damaging the laser assembly whilst handling to replace the caps. It's only the 2 connections, I just mention it so you know there are options, as it's only about 5 caps, but my preference was to be sure the laser assembly was protected.
Before starting the mainboard replacements I always like to mark the tops of the old caps with a Sharpie to make sure my progress is tracked:
- PXL_20231028_114855323.jpg (417.38 KiB) Viewed 1229 times
It is a slower process as it means I do one at a time, but that's fine for me. One thing I did find with the Saturn board is that the combination of large ground planes and very hard solder made the caps quite difficult to desolder.
I ended up using a 2 pronged attack as my desolder gun, even at 480C couldn't melt the solder, so I used a heavy tip on my iron at 450C, which with some flux did allow the solder to melt, and then brought in the desolder gun to suck the solder away.
I don't advocate high temperatures, I usually work at 370C for my iron, and about 390C for the desolder gun, but as long you are sensible and don't over do things, it works very well. The Saturn board really does seem to be quite hard to work with (At least my VA9 variant) and does need some alternate soldering techniques.
The final result can be seen here:
- PXL_20231028_153135439.jpg (370.07 KiB) Viewed 1229 times
You can see the 30 odd old capacitors just behind the board, and this brings me to the problem of the cap kit from Retrosix.
You can see that some caps have had to be laid on their sides in order to allow the top RF shield, which MUST be fitted because the CD drive mounts are on there. These caps that are laid down are normally low profile, but they are not low profile in the kit, whereas the rest are fine. I added a spot of hot glue to these caps to prevent any movement.
I really don't like this, it looks a bit 'bodgy' and while the kit contains enough caps for any variant of Saturn, for me, it's a poor option when you have to make compromises like this, so despite it being a reasonable price, containing decent quality capacitors and covering many variants, I don't think I can recommend it as a kit. To add to this, the kit doesn't contain the 5 caps needed for the PSU, so I will need source those separately.
Stability of the Saturn has definitely improved, so worth doing though. Also, despite the trouble soldering, props to Sega for clearly marking the capacitor polarity on the top of the mainboard, but also for marking capacitor locations clearly on the underside of the board, it certainly made the process much easier.
Now, where did I put my Space Harrier disc :)
