Page 126 of 173
Posted: 14 Nov 2025 16:01
by luciodra
Atarian Computing wrote: 14 Nov 2025 15:47 Thanks so much for the comprehensive reply @agranlund. It all makes sense now. I have a lot to learn about PC sound from the 90s. Dad always had a PC since the XT days but I was happy with my STE and hardly touched them at all.
I tried Notator and Cubase. Notator would not even launch properly. Cubase loaded up fine and let me load a midi file but I couldn't get any sound output. I tried different settings but it probably is as you suspected with the ACIA and all.
Which version of Cubase can you run? I'd like to try it but I can't at the moment. A few months later I managed to start it, but then...
Posted: 14 Nov 2025 16:09
by Atarian Computing
luciodra wrote: 14 Nov 2025 16:01 Which version of Cubase can you run? I'd like to try it but I can't at the moment. A few months later I managed to start it, but then...
3.10 which is the latest I believe. I got it from my own repo: https://filerun.atariancomputing.com/gu ... d5d82fc6fb
Posted: 14 Nov 2025 16:36
by agranlund
DoG wrote: 14 Nov 2025 14:26 Wow! I looks like that page was built 1999 :shock: :D
I love it! Fits the customer base and the target computers :)
Posted: 14 Nov 2025 16:52
by agranlund
Atarian Computing wrote: 14 Nov 2025 16:09
I'm surprised it started :)
But yep, the MROS it comes with does Atari built-in midi by direct hardware access.
That part I think was removed, and suitable driver was added to get Cubase going on V4SA. I'm sure it can be possible to piggyback on the hard work done by Pep and make a driver using Atari Xbios or direct-ISA etc.
I'm not sure if I'm imagining or not, but I want to recall something about some EmuTOS incompatibility too but I'm not 100% there.
But as far as I understand Cubase does at least work to some degree on V4SA, which runs EmuTOS.
Posted: 14 Nov 2025 19:11
by luciodra
Ok, work :D
Posted: 17 Nov 2025 17:18
by luciodra
I purchased the HD Drivers but I can't install on Raven!!!
What am I doing wrong?
Where are you leaving from?
Ok, solved after RESETVM.PRG :shock:
Posted: 22 Nov 2025 14:59
by LarryL
Hi,
What kind of wireless Keyboard/Mouse are you guys using?
I bought a cheap set from HP with a 2.4G USB Dongle
Keyboard works fine but Mouse is freaking out - jumping around the desktop.
Maybe too much DPI? can switch between 1000/1200/1600 DPI - but all three are unusable
Cheers
Michael
Posted: 22 Nov 2025 16:09
by PhilC
LarryL wrote: 22 Nov 2025 14:59 Hi,
Cheers
Michael
I've had the same issue, it probably needs a small firmware tweak to slow down mouse sampling or something like that.
Posted: 22 Nov 2025 16:57
by Mikerochip
PhilC wrote: 22 Nov 2025 16:09 I've had the same issue, it probably needs a small firmware tweak to slow down mouse sampling or something like that.
A friend of mine, borb, was looking at building a raspberry pi pico replacement for the eiffel, etc, and he found that there was a large range of DPI hard set on even the small sample size of mice that he had at home,
so, for his set up, I believe he implemented a set of sampling rates, that are user selectable.
I wonder if something similar is needed here?
I think he was looking at getting a dynamic dpi range working, by looking at the hid report dpi, but, I don't remember how far he got, or, even if he found it to be viable.
Posted: 22 Nov 2025 17:49
by PhilC
@Mikerochip Agranlund has swapped the pic normally used in the Eiffel for a Chinese stm32 copy and made the software compatible with the Eiffel app but has also added USB, bus mouse etc, so I suspect a sampling rate change or whatever is required will be quite easy to do.
