Page 13 of 21
Re: RJ's Attempt. Maybe he's going to finish this time!
Posted: 05 Mar 2020 23:13
To be fair, it still needs some work, but very happy overall 😁
Posted: 06 Mar 2020 00:26
Just knocked up a floppy cable and hooked up a hard disk.
Both working fine, just need to go to bed now!
Posted: 06 Mar 2020 10:45
Assume you have the DMA patch PCB then ?
Posted: 06 Mar 2020 11:34
exxos wrote: 06 Mar 2020 10:45
@exxos Actually I don't. TBH I havent tested extensively so it may not all be roses.
Posted: 06 Mar 2020 11:45
rubber_jonnie wrote: 06 Mar 2020 11:34
I was going to say, the hard drive will not function correctly without the patch board, or jumpering over the chip like we did as a test a while back..
Posted: 06 Mar 2020 11:52
exxos wrote: 06 Mar 2020 11:45
@exxos I'll see how it behaves and I'll get back to you.
Posted: 06 Mar 2020 13:29
@exxos Ok, I just read back through the DMA Issue thread and I'm not currently using ACSI for connecting my hard drive.
Because I have the BETA IDE interface in use, basically so I can override the onboard ROM access problem, that's what I'm using for my HDD.
I ran a few tests on it over lunchtime, nothing major, things like file copies from FDD to HDD, other general file access stuff, and it works just fine.
I just left it running the crappy IDE hard drive tester, so will see what that throws up, and when I have time I'll see what XFFRATE says.
I'll probably test with my CosmosEx (ACSI) this weekend, but it does sound like I'll need the PCB for that to work properly.
Posted: 06 Mar 2020 13:36
@rubber_jonnie The patch board is for the DMA hard drive port, DB19 socket etc... IDE uses a different bus (*hides*) so it is unaffected by that part of the circuit.
Posted: 06 Mar 2020 14:44
exxos wrote: 06 Mar 2020 13:36
@exxos yep, that figures.
I presume it's a case of ordering your own patch PCB, or do you and Icky have some we can buy?
Posted: 06 Mar 2020 14:54
rubber_jonnie wrote: 06 Mar 2020 14:44
@Icky Got a few made which he's going to send to me at some point soon... I'll probably just put them in the post for people in the UK who want them, is not worth bothering adding them to my store just for the sake of a couple of boards..
Icky paid for the boards to be done, so me selling them is slightly unfair to Icky. But also unfair on others if I force them to buy boards to fix something I ballsed up in the first place.
For people overseas, they can get them from OSH cheap with free postage anyway.. There was also no point people in the UK ordering from OSH as it will take over a month just to get the boards..
