Page 13 of 22
Re: TF536 on A2000
Posted: 03 Aug 2020 08:39
by dalek
terriblefire wrote: 03 Aug 2020 08:26 I dont want people using the forum to fine binaries long term. Github has what you want.
Awesome! Thanks :)
Re: TF536 on A2000
Posted: 03 Aug 2020 13:33
by matt020
Are there any Australian users here that can re-flash CPLD's?
Re: TF536 on A2000
Posted: 03 Aug 2020 13:46
by dalek
matt020 wrote: 03 Aug 2020 13:33 Are there any Australian users here that can re-flash CPLD's?
Yes but on the wrong side of the country. Happy to do e.g. a return express post satchel if you can't find anyone closer.
There's the Raspberry Pi flashing option too if you haven't seen it.
Re: TF536 on A2000
Posted: 03 Aug 2020 13:51
by PaulJ_2.0
dalek wrote: 03 Aug 2020 13:46 There's the Raspberry Pi flashing option too if you haven't seen it.
This^
You can make up a cable easily enough and use a pi zero w to do it all wirelessly with putty from a computer in seconds.
There is also a sd card image here on the forums you can use to simplify it all.
Re: TF536 on A2000
Posted: 03 Aug 2020 14:11
by matt020
Dalek : Ive put a request out on a local FB group, if I have no luck I might overnight air it to you if that's cool?
PaulJ: Do you know where (which section or subsection) the SD card imagine is in, for the chance that I find someone local with a Pi?
Cheers, thankyou!
Re: TF536 on A2000
Posted: 03 Aug 2020 14:48
by PaulJ_2.0
Here is mine:
Re: TF536 on A2000
Posted: 03 Aug 2020 14:50
by PaulJ_2.0
Dont you get Amazon next day there in Aus?
Raspberry pi zero w are cheap as chips
Re: TF536 on A2000
Posted: 03 Aug 2020 16:42
by terriblefire
A pi zero will cost less than postage across Australia
Re: TF536 on A2000
Posted: 03 Aug 2020 23:08
by Danoo
@matt020 you can get a Pi Zero from Core Electronics around about $10 plus 3$ shipping (non W version) based in Sydney I think, if you want to have a crack at programming the card yourself. There maybe even cheaper suppliers.
I also have a Xilinx programmer and could do the update if needs be, but the postage across the country and back as @terriblefire suggested would be probably be a lot more than the pi. :)
Re: TF536 on A2000
Posted: 03 Aug 2020 23:09
by terriblefire
Guys this topic is not about flashing a TF536. there are others that cover it.
