Page 13 of 25
Re: Terriblefire Accelerators
Posted: 29 Nov 2018 21:47
by SukkoPera
AIBB looks OK and all tests run fine.
I have just experienced the same issue I had on the A500+: every time I write to the CF, it gets totally corrupted.
Posted: 30 Nov 2018 00:27
by SukkoPera
OK, I reconfigured the expansion to 1 MB slow and the CF write issue seems gone.
I have tried the Memory Test in SysTest and with 1.5MB it fails with X's for all bits right at the start of the 0xC0000 range, weird.
Posted: 30 Nov 2018 08:06
by terriblefire
SukkoPera wrote: 30 Nov 2018 00:27 OK, I reconfigured the expansion to 1 MB slow and the CF write issue seems gone.
Did you mean 0xD00000? Either way if alenppc isn’t seeing the issue I’m betting you have an issue like a short somewhere on the address bus.
Posted: 30 Nov 2018 09:07
by SukkoPera
I will check again tonight and post a pic of the failing test.
I don't think I have any issue on my machine, as the full 1.5MB range tests fine with the original 68000 CPU and 1 MB seems to work well with the TF card.
Some guy was mentioning in the PeteAU's expansion thread on EAB that to get a 100% working setup he had to use the latest bus JED but the previous RAM JED. Does that make any sense?
Posted: 30 Nov 2018 09:18
by terriblefire
It will be a short on the TF530 if there is one
Posted: 30 Nov 2018 12:56
by alenppc
I will take another look at this also this weekend to see if I can reproduce it by booting Lotus II from WHDLoad. To be honest I haven't tested every game, but I've run Nemac IV, Frontier and a few others.
Posted: 30 Nov 2018 13:22
by ICRY
Hello I know you have a lot going on, so just wondering when the TF534 might be released for people to build.
Amazing work btw!
Posted: 30 Nov 2018 22:56
by terriblefire
I'm planning to release them when I am sure i can get a set of gerbers that will work. I'll also sell what i have on eBay at the same time.
Posted: 01 Dec 2018 17:41
by SukkoPera
terriblefire wrote: 30 Nov 2018 08:06
I've checked again and it fails in the 0xC00000-0xC7FFFF range, see pic (please ignore awful video quality):
Foto 01-12-18, 18 38 13.jpg (95.39 KiB) Viewed 4616 times
Posted: 01 Dec 2018 17:43
by SukkoPera
SukkoPera wrote: 30 Nov 2018 09:07 Some guy was mentioning in the PeteAU's expansion thread on EAB that to get a 100% working setup he had to use the latest bus JED but the previous RAM JED. Does that make any sense?
Should I try this?
