Page 118 of 215
Re: Stuff and Things.
Posted: 12 Jun 2023 16:08
by mrbombermillzy
rubber_jonnie wrote: 12 Jun 2023 16:05 Indeed it could be something like that, however I do store cables very carefully to avoid hard bends, but the I'll compare to the new cable when it arrives.
I'm sure you do. :)
I'm just thinking about eliminating the cable from the equation as being the point of fault. i.e. The cable may be fine.
Posted: 12 Jun 2023 16:24
mrbombermillzy wrote: 12 Jun 2023 16:08
I'm sure you do. :)
It doesn't work on my Atari 800XL either, same thing, monochrome. It definitely could be the cable for sure.
Posted: 13 Jun 2023 13:45
This arrived in the post at lunchtime:
And the picture is definitely improved for sure and any fuzziness on the menu at top left has gone:
As you can see, the word 'ROBOTS' is actually clear and has no bars or artifacting, and the general image is much nicer, with much less artifacting:
Certainly the area where the player is stood is much improved for sure, and I think the rest is simply artifacting from the dithering used. I need to weave this cable into my video switch environment now, it'll look great.
Posted: 13 Jun 2023 13:49
by PhilC
That's much better
Posted: 13 Jun 2023 14:06
PhilC wrote: 13 Jun 2023 13:49 That's much better
Isn't it just :) I'm certainly happy with it this way for sure as the overall picture quality on other things is superb.
I have a feeling my other cable is for Atari and on checking, it's missing the middle pin, pin 6 out of 8, which is for chroma, hence why the original cable was only outputting monochrome.
It looks like the original 5 pin socket on the early C64 was composite only.
As for my Atari cable, IIRC I used it on my 65XE before I upgraded to VBXE and that has proper S-Video out.
Posted: 22 Jun 2023 10:20
Quick project done, a BlueSCSI:
So far so good, it recognises the hard drive files on the SD card and generates the necessary log file, so it seems I have a working Blue Pill :)
Screenshot 2023-06-22 at 10.19.48.png (94.61 KiB) Viewed 1312 times
Next is to try and use it with my Archimedes A5000 as the old Apple SCSI drive I currently have in it seems to be failing.
I'll probably build a 2nd as they have a very low component count and are very quick to build.
Posted: 22 Jun 2023 12:15
by JezC
rubber_jonnie wrote: 22 Jun 2023 10:20 I'll probably build a 2nd as they have a very low component count and are very quick to build.
Would be interesting to see the links for the BoM for this etc. - especially since the RasPi pico solution from the store have sold out already :(
Posted: 22 Jun 2023 14:25
JezC wrote: 22 Jun 2023 12:15
I had an online BoM, will see if I can find it, but there really is not much tbh.
Just out ATM will get back to you.
Posted: 22 Jun 2023 14:43
by JezC
rubber_jonnie wrote: 22 Jun 2023 14:25 [I had an online BoM, will see if I can find it, but there really is not much tbh.
:thumbup:
Posted: 22 Jun 2023 15:33
by DoG
BlueSCSI v1.1 assembly guides and BOM from Mouser. The BOM is also listed at the top of each assembly page.
