Page 12 of 12
Re: Amiga 2000 stopped working...
Posted: 18 Jun 2024 18:16
by stephen_usher
It could have potentially burned through some oxidation.
Anyway...
:yay2: :dualthumbup: :cheer: :girldance: :cheers:
Posted: 18 Jun 2024 18:27
by Kepler
I think you may be right...or did my mistake cause a short to be "blown out"?
I once read - on an electronics forum - that shorts could sometimes be corrected by increasing the current (?!) flow through the track or component. It didn't seem particularly believable at the time, but perhaps I serendipitously proved it's veracity?
Posted: 18 Jun 2024 19:04
by stephen_usher
It can happen with solder whiskers but I think it's just luck. :-) You probably knocked the Gary changing the bad connections.
Posted: 18 Jun 2024 22:14
by terriblefire
Well done!
Posted: 18 Jun 2024 22:38
by BennehBoy
Glad it's sorted.
Posted: 19 Jun 2024 04:28
by Kepler
Thank you, all. As I mentioned earlier, there are lots of useful fault diagnosis guidelines that ought to be invaluable for others experiencing the same symptoms.
Posted: 19 Jun 2024 06:57
by supaduper
I love a happy ending :D
Re: Amiga 2000 stopped working... (FIXED)
Posted: 19 Jun 2024 10:33
With regard to 'blowing out shorts' It's not something I'd like to use as a troubleshooting methodology, however I do sometimes use voltage injection with a low voltage like 1v. It's usually good enough to highlight bad ICs when they get warm, and if you get an instant high current draw then you are almost certainly looking at a short.
Glad to see it running again, and I know what you mean about just waiting for machines to die, it's inevitable, but at least having the skills to repair is a good thing :)
