stephen_usher wrote: 20 Sep 2023 18:07
exxos wrote: 20 Sep 2023 16:35
Looks like it's a step up from 9v to 12v. So if no load on the 12v the regulation wouldn't work and could well spike up to 50v. Ive not been following close enough to know the test done.. But if no load then the behaviour would actually be normal.
There's some load, the video encoder chip, but not as much as if the 4116s were in circuit. The -5V and -12V would also be fully unloaded.
@rubber_jonnie You could replace the whole of the spectrum DC-DC conversion circuit with one of these:
https://www.ebay.co.uk/itm/265904298733
Sorry I didn't reply until this morning, I was in the office yesterday, and it's a very long day for me.
I tested the coils on both the + and the spares board again, there are no shorts between windings.
So I got some new TR4s and fitted one to the good board. 30v this time but I removed power PDQ and had already pulled the ULA and LM1889 for safety, so no harm done on this occasion. I pulled the transistor to re-use on the spares board.
When installed on the spares board, which still has the 4116 RAM installed, the results were different, I got a steady 7-8v for about a minute and then the transistor popped. It seems like these 4s boards are unhappy fellows and like to pop TR4s like no tomorrow. The RAM may have dead IC's though, causing an overload condition that pops TR4.
So, I'm going to pull the 4116 RAM from the spares board next and fit another TR4 and see if the results match that from the + board, i.e. 20-30v without the load, or if it runs happily and delivers 12v.
But I'm guessing without the load on -12v and -5v it's going probably going to run away again.
I could remove the hacked 4164s and drop in the spare 4116's I have to determine if the load changes with the -5v & -12v rails in play, however if I get 20-30v again, that's my spare 4116s lightly toasted. I'm not keen on that option.
So I think it likely that I need to do 1 of 2 things.
The PSU provides 11v, and if I steal that from the input, I can inject that into the dead 12v circuit (At D15, on the same side as C78) and the machine runs just fine. I'm not overly keen on that idea since it's taken directly from the PSU input and unregulated. If the PSU goes bad, the consequences could be catastrophic. Though given the 30v I have been getting on the original circuit, is it that much worse?
Alternatively, there is the suggested boost regulator. I can feed it 5v from the regulated power line, and it should offer a level of isolation from the PSU. Time to get ordering.
For reference the issue 5 circuit is below:
EDIT: Boost converters ordered.
