Been somewhat quiet lately, in part because I have been working on stock items continuously, but secondly my hands been in agony for the past couple of months so really trying to not do too much lately. I also had a lot of breakdowns on my van lately as well which has been keeping me rather busy :roll: I have not been sleeping much with all this heat lately as well :cry:
I have been trying to fit a larger SSD in my PC the past couple of days.. A 860 EVO... Long story short, it seems no end of people have been having problems with AMD's 990 series chipset.. Which is what my motherboard has :roll: I kept getting random freezes, like there was a bad cable, but I swapped cables around loads of times. while doing various file benchmarks, it always seemed to freeze in the same place, or when doing backups it always got to a certain point then froze.
There does not seem to be a solution for this, so I looked through my bits box and found this old SATA card.
https://www.startech.com/support/PEXSATA22I
- IMG_5453.JPG (352.12 KiB) Viewed 3785 times
Which then brought me onto the next problem that it did not physically fit in the PC because the chipset heatsink was in the way :roll:
- IMG_5454.JPG (248.09 KiB) Viewed 3785 times
So the quick fix was to just break some things off and remove the stupid top nameplate of the block..
I cannot use the bottom part because the heatsink is in the way bought I only wanted one port anyway...
- IMG_5455.JPG (291.57 KiB) Viewed 3785 times
so picked up the drive straight away which was good luck !
- IMG_5456.JPG (162.71 KiB) Viewed 3785 times
but it was short lived as Windows did not have the driver :roll:
They are actually on manufacturers site
https://www.startech.com/support/PEXSATA22I but took a bit of finding as you have to click the support tab..
- xxx.JPG (17.09 KiB) Viewed 3785 times
So running file benchmark once again and it actually completed this time!
- xxx2.JPG (84.04 KiB) Viewed 3785 times
Now one of my backups of the day is well underway..
- xxx3.JPG (39.46 KiB) Viewed 3785 times
The actual card is rather slow though and seems to max out around 120MB/sec... So may get another card in the future such as this one..
https://www.ebay.co.uk/itm/Expansion-Ca ... 4256859867
Just found this card in my bits box,so will try this one next..
https://www.startech.com/Cards-Adapters ... d~PEXSAT32
EDIT2:
New card in.. (wish I found this one first! :roll: )
- IMG_5458.JPG (237.85 KiB) Viewed 3775 times
New benchmark..
- 13-August-2020_13-30.png (102.09 KiB) Viewed 3775 times
I can live with that :) Shame the writes are pretty slow compared to the MB chipset :(
Just for completeness, this is my 850 PRO on the MB chipset...
- 13-August-2020_13-33.png (105.06 KiB) Viewed 3775 times
