Page 11 of 12
Re: The age of Aquarius
Posted: 10 Feb 2022 12:30
by stephen_usher
:lol: :dualthumbup:
Posted: 10 Feb 2022 12:34
by stephen_usher
Crossed fingers emoji is
  • Unicode: U+1F91E
  • Short code: :crossed fingers:
Unfortunately no magic smoke Unicode emoji. :-)
Posted: 10 Feb 2022 12:53
stephen_usher wrote: 10 Feb 2022 12:34 Crossed fingers emoji is
  • Unicode: U+1F91E
@exxos should definitely look for a magic smoke emoji!
:crossed fingers: he can find one :)
Posted: 10 Feb 2022 13:53
by sporniket
rubber_jonnie wrote: 10 Feb 2022 12:53 @exxos should definitely look for a magic smoke emoji!
When I read "magic" I propose
source
edit : that said, a little bit heavy
Posted: 10 Feb 2022 14:03
by stephen_usher
Something akin to that?
Or based upon this?: https://commons.wikimedia.org/wiki/File ... n_fire.svg
Posted: 10 Feb 2022 14:23
sporniket wrote: 10 Feb 2022 13:53
source
:lol:
Posted: 10 Feb 2022 14:26
stephen_usher wrote: 10 Feb 2022 14:03 sick-computer-icon-260nw-227620936.jpg
I like the 2nd one :) and this one too:
Posted: 14 Jul 2026 12:35
OK, it's be a while since I posted anything 'proper' and whilst feeling ill I decided to have a quick look at my Aquarius mini expander, which I was never able to get fully working previously.
I burned a new ROM with USB BASIC (Supports USB sticks) but decided to just go back to the basic ROM/RAM board, removing the AY8910 sound chip and CH376 module. That all fits nicely into 64K since BASIC is 32K and the games are 16K each. I might have to fit some switches for ROM selections though to make it easier than jumper selecting that requires the expander to be removed to switch options.
It seems that the main issue is a poor connection in the ROM slot, but I'm happy to say after a bit of cleaning I now have 3 working ROMs:
USB BASIC
Burger Time
Advanced Dungeons and Dragons.
I may go and do a deeper clean of the ROM slot though and also see if I can reflow the pins on the socket as it does have the capability to flex as the design is simple and not mechanically strong.
That's a big win, especially since the 32K RAM expansion is also working. Next I need to fix up the CH376 USB device, for which I now have a couple of spares. I'm just going to use an IDC cable for now so I can play around with it until it works rather than soldering it in.
Posted: 14 Jul 2026 14:37
OK, so I just grabbed the schematic for the Micro Expander and checked the connections for the CH376. They are off by a long way.
This is the schematic:
and closer up:
And this is the pinout of the CH376:
So I'm going to need to adapt this for it to work properly. Explains a lot though.
Posted: 14 Jul 2026 23:35
Interestingly it seems the wiring was fine, there seems to be a discrepancy with the schematic, however I have split the CH376 out and put it on the end of a cable and it's like having a little floppy drive connected.
The cause of the errors with the USB stick not reading turned out in the end to be a bad CH376 module, the replacements I bought work just fine, how annoying is that!!!
The culprit is on the right:
And some gratuitous shots of it just working :)
