Re: Steve's H5 A3.14 Build (Chicken Pie edition)
Posted: 21 Jan 2022 12:39
Have you put this in your ff.cfg?
pin02 = ndens
pin02 = ndens
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
That does not make sense.. If you force 1.44mode then you cannot use 720k floppies unless you "force" 720k mode. It's why you need the bodge wire on the floppy drive to the jumpers to made it switch automatically. If you are forcing one mode and using a different density floppy then of course you will end up with a lot of problems.Steve wrote: 21 Jan 2022 12:10 In the H5 I put it in 'force 1.44mb mode' and in 'GAL mode'. It read a 720k disk perfectly (which the Epson did not do) but struggling with 1.44mb disks,
Yeah but I'm forcing 1.44mb mode and it isn't reading 1.44mb. I think we are having a communication problem here :) (obviously my H5 knowledge isn't any where near yours, I am assuming I need to put it in 1.44mb mode please correct me if I'm wrong) I am only testing a 720k disc for troubleshooting purposes, and in this case it reads it, which is an interesting bit of info? :)exxos wrote: 21 Jan 2022 12:40That does not make sense.. If you force 1.44mode then you cannot use 720k floppies unless you "force" 720k mode. It's why you need the bodge wire on the floppy drive to the jumpers to made it switch automatically. If you are forcing one mode and using a different density floppy then of course you will end up with a lot of problems.Steve wrote: 21 Jan 2022 12:10 In the H5 I put it in 'force 1.44mb mode' and in 'GAL mode'. It read a 720k disk perfectly (which the Epson did not do) but struggling with 1.44mb disks,
No, lemme get the details to you later, am just at work still.Steve wrote: 21 Jan 2022 13:50 @PhilC maybe we can have we can have a chat over the phone to help me understand. I think what you're telling me is that I've modified the Sony drive to 720k with moving that SMD resistor? If that is the case I didn't realise it because the terminology used on the forum and on the guide is 'move the resistor to make it Atari compatible' so I didn't know it referred to the disk size.
If that's the case I'll move it back, and the wire mod is still correct though right? Pin 2 to the select point.
That is the drive ID jumper. The H5 was designed so you don't have to do that mod at all.Steve wrote: 21 Jan 2022 13:50 ...forum and on the guide is 'move the resistor to make it Atari compatible' so I didn't know it referred to the disk size.
Then as said a few posts back you need to check pin 1 of JP22 to see if you're seeing 16Mhz there.Steve wrote: 21 Jan 2022 14:42 at the moment my H5 is set for 1.44mb mode and it isn't reading 1.44mb (pin 18/19 open, in gal mode 1-2 for the other jumper)
