Page 11 of 15
Re: 330 disable function bug
Posted: 26 Jan 2025 15:21
by supaduper
You dont need it to be in the CD32 to flash the card but try it if you want to it will not hurt
Posted: 26 Jan 2025 15:58
by Mister_Grave
Haha great, that's perfect... The tf330 no longer works now...
I turn on the CD32 and the orange light stays on. No image nothing.
Posted: 26 Jan 2025 16:07
by supaduper
Flashing the board in the CD32 will not hurt nothing , sounds like you are getting frustrated best to take a break for a bit and try again later
Posted: 26 Jan 2025 16:09
by Mister_Grave
I haven't tried flashing in the CD32. Since it didn't work with the Raspberry, I removed all the cables and reconnected everything correctly in my CD32. The problem is that the card seems dead...
Posted: 26 Jan 2025 16:13
by supaduper
Send back to the seller and just explain that you are having problems flashing the card, most Amiga stores are very helpful and I am sure the Spanish one is too, its a pain I know but these things happen
Posted: 26 Jan 2025 18:49
by Mister_Grave
I think I'm going to buy a Xilinx jtag, it's not very expensive. Given the price to pay to send to Spain, I prefer to invest it! I think the flash simply messed up in the middle because of the Erase problem (03). I guess if I reflash it should be fine.
Posted: 26 Jan 2025 19:22
by supaduper
Yes if you get a Xilinx programmer ( will be a clone because genuine one is crazy money ) you can sort it out no problem
Posted: 27 Jan 2025 07:01
by Mister_Grave
Find this one.
https://amzn.eu/d/6f4ijQp
Coming tomorow.
Posted: 27 Jan 2025 07:22
by supaduper
Hopefully should work, but installing the hardware can be a pain as it is a big download package over 6gb and you will need to probably install it on a earlier windows system w8,
you only need to use the program Impact in the software package, its a smaller download 1gb and its all you need really, I have put a link to my Xilinx Lab tools that has IMPACT in it below for you
Obviously you will use it in the JTAG mode and the pinout is clear on the programmer label
https://mega.nz/file/Zw5jkYqS#LI62nalPL ... G5dh2hA4eM
Posted: 27 Jan 2025 14:26
by Mister_Grave
supaduper wrote: 27 Jan 2025 07:22 Hopefully should work, but installing the hardware can be a pain as it is a big download package over 6gb and you will need to probably install it on a earlier windows system w8,
Thanks a lot !
