See previous post. It looks very good. Never seen it before.
The problem with cycle accurate CPUs is that is not what you want for new accelerators. You don't want a 13-cycle multiplier/divider you want all instructions to be single cycle (like TG68K DotC)
Re: 68881 VHDL implementation
Posted: 21 Sep 2026 14:48
by Kochise
alexh wrote: 21 Sep 2026 14:36
First commit is from Jul 4, 2026 so I not checked in the meantime.
Still, nice to find such projects, obviously also coded using AI (perfect use case).
Then go for the 68060's integer multiplier :) Or the VIA Nano 3000.
Posted: 21 Sep 2026 14:49
Have all these cores actually been tested on real hardware ? As it mentioned Claude as contributor, you can probably knock out loads of cores in a week. Doesn't mean to say they work..
Posted: 21 Sep 2026 14:55
by Kochise
Both have reference hardware implementation for validation :
And they claim to have been simulated with a quality test-bench. I've not tried either but there is a lot of polish here. I'm seeing all the right stuff. And the HDL doesn't look too much like AI code.
Posted: 21 Sep 2026 15:24
by Kochise
Obviously the commits say otherwise. But in the end it's the result that "counts"...
