Page 2 of 5
Re: RGBtoHDMI for STe -some questions
Posted: 23 Sep 2026 20:27
by alexh
DoG wrote: 23 Sep 2026 19:19 Is BLANK signal not needed on the STe RGB2HDMI board?
What is that? RGBS is everything.
Posted: 23 Sep 2026 21:54
by Pacman
Steve wrote: 23 Sep 2026 14:15 @Pacman I managed to install RGBtoHDMI in two of my STe's following those spotty forum posts, but I am no expert. You probably know more about it than me now.
Not sure about that, but I think I more or less get it now. And it's reassuring that you and other STe users have it working :)
In terms of making a standard installation method, perhaps @exxos may be interested in modifying his STe DAC upgrade board to being more of a RGBtHDMI pick-up board: https://www.exxosforum.co.uk/atari/last ... /index.htm
I like your idea, for a number of reasons! :thumbup:
I had a quick read through it and although the idea is certainly a good one I'm not sure if it's ideal for the general STe users wanting to get an HDMI output first of all because it involves major "surgery" to the motherboard.
Also it's not suitable with STe motherboards containing a 32MHz oscillator positioned at U402. I'm not sure how common this is or if I even have one in mine, so this may or may not be an issue.
UPDATE: I just checked my two STe machines.
One has a 32MHz oscillator while the other one doesn't, so in my case the DAC board is only suitable for one of them.
But... I'm struggling with how (and where) to mount my RGBtoHDMI buffer board, so the photos gave me some ideas. I need to do some serious head scratching here so as to make it easy for the average Joe to install with the limited options possible and with a stable connection to the resistors.
Obviously the board should be as close as possible to the signal source (i.e. the row of 13 resistors connected to the video shifter PLCC IC), and that's underneath the power supply.
One idea that's crossed my mind is to take advantage of the power supply's four mounting holes and design a 3D-printed "frame" for the PCB underneath the power supply using the same mounting screws. But of course I don't know the first thing about 3D printing or even how to create a design so I can order it printed from somewhere :o
Then again, everything starts with an idea and the practicalities can usually be solved somehow :D
Posted: 23 Sep 2026 22:03
I don't know how the RGBtoHDMI things hooks up, id assume it just plugs into the RGB port on the STe as most things do ?
If you're talking about picking the signals up earlier, then just don't connect the RGB DAC outputs to the transistor area.. and you already have your RGB output there anyway..
I did get the updated boards made, but they have been sat in the box for the past few months as I haven't had time to try them yet.. If it's just a case of adding a connector or extra pads then that can probably be done on the future batch anyway..
Posted: 23 Sep 2026 22:18
by Pacman
stween wrote: 23 Sep 2026 18:25 My own resistor notes, which I assume echo the threads above:
It does mean a bit of a rat's nest of wires and I'd love if it was cleaner. I'm always paranoid that I'll have a weak solder joint in that mix. My kingdom for something more stable!
Thanks. I compared it with my own findings and the resistor connections (from the video shifter PLCC chip) were the same as yours.
But shouldn't the CSYNC output go to pin 12 ("SYNC") of the IDC cable?
Posted: 23 Sep 2026 22:52
by stween
Pacman wrote: 23 Sep 2026 22:18Thanks. I compared it with my own findings and the resistor connections (from the video shifter PLCC chip) were the same as yours.
Long time since I looked at this. Suspect I was using this page as one of my sources: https://blog.jokielowie.com/en/blog/ata ... ry-pi-zero
Suggests the way I did it works for so long as you have a model with an RF modulator.
Posted: 23 Sep 2026 23:46
stween wrote: 23 Sep 2026 22:52 Long time since I looked at this. Suspect I was using this page as one of my sources: https://blog.jokielowie.com/en/blog/ata ... ry-pi-zero
Great write up. Might be worth posting it on the wiki :)
Posted: 24 Sep 2026 09:39
by Pacman
That page is one of my sources as well, for the buffer I'm working on. It's the only one I've found describing how to add a buffer in an STe (if you don't want to start from scratch that is).
Unfortunately there's a mistake with the modified Amiga buffer PCB (shown near the bottom of the page) where the 3rd pin (marked in pink) should actually be the 4th pin. The author is aware of this. The schematic below should be correct though.
By the way, I see you take +5V and GND from the STe motherboard. Does this power up the entire RGBtoHDMI setup including the Raspberry Pi Zero, or do I need to power the Pi Zero separately using its USB-Micro power connector?
Here's a schematic I made of the Amiga 12-bit buffer, modified for the Atari STe.
I hope to complete it with a PCB that'll fit underneath the power supply (or some other place near the video shifter PLCC chip) with the connections routed appropriately, connectors added etc.
NOTE: If you want to connect the IDC cable directly to the RGBtoHDMI/extender board (i.e. you don't want to add the buffering circuitry in between) it should be a matter of just bypassing the two 74HCT245 buffer chips (i.e. A1 connects directly to B1, A2 connects directly to B2 etc. of each chip).
Atari STe 12-bit buffer 0.10.1 schematic.png (282.56 KiB) Viewed 144 times
:!: I've triple checked the connections in the schematic but haven't actually built and tested it, hence marking it as "preliminary".
:!: If someone finds an obvious (or not so obvious) mistake, please do tell! I'm just a hobbyist, still learning :)
Posted: 24 Sep 2026 14:49
by stween
I know nothing about buffers, I'll admit! I'm not a video guy: what would that improve?
Pacman wrote: 24 Sep 2026 09:39By the way, I see you take +5V and GND from the STe motherboard. Does this power up the entire RGBtoHDMI setup including the Raspberry Pi Zero, or do I need to power the Pi Zero separately using its USB-Micro power connector?
Yeah, it's ribbon-in and HDMI out, and that's it. No external power. I just have no good solution to the mess of wires!
Posted: 24 Sep 2026 16:58
by Pacman
stween wrote: 24 Sep 2026 14:49 I know nothing about buffers, I'll admit! I'm not a video guy: what would that improve?
Well, I'm no expert either (just someone who's handy with a soldering iron, knows a little bit about several things, has a little too many ideas and try to get some of them completed :lol:
A buffer in this case should first of all protect the custom made Atari PLCC squared shape "GST video shifter" chip (U401 on the STe motherboard) where the bunch of wires to the RGBtoHDMI board originates from in case of static electricity or whatever. It should also improve on the signal (especially with a long cable connection).
There are differing views on all this where some people say it's overkill and makes no practical difference to connecting the wires directly between the STe and the RGBtoHDMI hardware, while others (such as myself) say I'd rather stay on the safe side just in case. Here are a few forum links:
Thanks for confirming. It's the kind of details which have been left out in most discussions (or I've missed it myself).
I did read something about the Raspberry Pi using 3.3V instead of 5V, but that may have been something else. If it's working and there's no smoke I assume everything's OK :lol:
As for the mess of wires: not an easy thing to avoid, but with the buffer I want to avoid that sort of thing if possible. I personally prefer non-permanent modifications which can easily be reversed if desired, so I'm looking into all sorts of practical solutions. I do think I'm going to end up with a short cable with a connector on it that goes into the STe buffer board, then a connector that mates with the 16-way IDC cable that goes to the RGBtoHDMI.
The good thing about cable mess like what you describe is that it can usually be undone by desoldering and using an improved solution (if available) with connectors, sockets or something. Been there, done that with various other (horrendous looking) projects.
I hope to figure all that out, and when I do, share it with the Atari community.
Posted: 19 Oct 2026 20:45
by Pacman
I'm struggling to find a way to get my buffer board mounted in a secure/practical manner.
The idea was to make a common board which will electrically work with both the STe and Mega STe, and likewise find mounting posts or screw holes on both motherboards (red circles in the photos) that can hold the buffer PCB (with multiple holes to accomodate both computers).
The red rectangles show the RGB/mono connections that connect straight into the buffer PCB. Typically wire ends of resistors and very short for signal integrity.
Mounting the PCB just over the resistors and finding mounting solutions seems like quite the challenge (inside the STe space is even more crammed than in the Mega STe with higher components (a transistor among others) to make that quite hard). So if I physically place the buffer board somewhere more practical in both computers, meaning that an IDC cable would be needed to attach it to the video shifter's resistors; would that degrade the video signal a lot? What would the cable length limit be for something like that?
Alternatively I see that STe/Mega STe users with the RGBtoHDMI currently have an IDC cable going all the way to the outside of the casing, and that's with no buffering at all.
