Re: Falcon Speed 286 emulator
Posted: 11 Sep 2026 14:31
I never thought about checking if Frontier had a CGA mode. Apparently it does!
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
Hmm, that would be interesting to find out, but I do not have the time to make such a version...SteveBagley wrote: 11 Sep 2026 14:25 Not when its running at 90% of the speed of the ST ;) 3D maths is CPU heavy, which the Amiga's chips don't really help with. The interesting question is how well the 286 would compare :)
I think it's also a hardware implementation issue as well as software. The Amiga Bridge boards and the Acorn PC emulators (RISC PC excepted) both feature dedicated RAM for the x86 chip and so it is able to run concurrently with the 68000/ARM CPU except when transferring data (the screen, more likely instructions to draw on the screen).Badwolf wrote: 11 Sep 2026 15:04 The poor old Amiga's inherent slowness aside for a minute, one thing that was left on the cutting room floor in my video was a rambling background thread about how restrictive the software for this is in the ST ecosystem.
True, but Falcon Speed relinquishes the bus every 18ms or so anyway (albeit for a very small time). Presumably to service interrupts? I would have thought event checking for window actions would have been possible at that rate.SteveBagley wrote: 11 Sep 2026 17:11 Conversely, with the (PC|AT|Falcon)Speeds the x86 and the 68000 both address the same (ST) RAM and so only one CPU can access RAM at any one time, this effectively makes multitasking both CPUs impossible -- at best, you could have the CPU's take turns to execute instructions and run both at half speed. It's effectively the same as your DFB1, or any of the Amiga accelerator boards -- once the x86 kicks in, the 68000 is just waiting.
Bah. Tried it. Needs a 386!
I started taking a look at the FalconSpeed and ATSpeed software in Ghidra earlier today, they definitely work in different ways. The ATSPEED software definitely uses $FFFC40/$FFFC80 to communicate as per the Atari STE+ service manual, but FalconSpeed seems to be mapped in a different way, which wasn't entirely clear. It almost looked like it was using similar memory locations to the IKBD/MIDI ACIAs to communicate (using the odd bytes as opposed to the even).Badwolf wrote: 11 Sep 2026 20:41 True, but Falcon Speed relinquishes the bus every 18ms or so anyway (albeit for a very small time). Presumably to service interrupts? I would have thought event checking for window actions would have been possible at that rate.
Don't forget that TOS and DOS will both be fighting over memory locations (they share the same address space), so it's a non trivial problem to switch between the two. Ideally, you'd want to be able to remap the x86's memory accesses to an arbitrary block allocated by TOS, but the logic to do that (without an MMU on the CPU) would be complex. I suspect IC6 is doing something interesting with the high byte of the addresses to help, though. My disassembly of the FalconSpeed (and ATSpeed) software suggests the Atari loads the BIOS in at $38000, although the 286 will (IIRC) access it at F000:FFF0, so something must be happening. The decoded equations will be interesting,I'm not saying it should magically multitask, but no thought is given to much Atari software about anything else running. Even being able to return to the desktop would be nice. Falcon Speed only uses 8MB for the PC, so even a clean exit rather than a reboot might have been nice as it ought not have to trash the OS.
Oh definitely, I think the Supercharger could do things like that? It was more like the Amiga Bridgeboards, a complete PC in a box which talked over ACSI to the ST.But wouldn't a PC in a window as a desk accessory have been cool? 8-)
Ooo, if you're looking at Ghidra (I still must learn to use that -- the few attempts I've had so far to play with it have ended in ignominy), let me know if you see anything related to IDE. Seems to be a big weak point. I suspect it struggles with modern devices for a couple of reasons. Timing may be one (there are a *lot* of lockups with my CF card) but the biggest hurdle is it doesn't seem to accept any *drive* over a figure between 64 and 256 MB. Perhaps cylinder count is stored as a byte?!SteveBagley wrote: 11 Sep 2026 22:32 I started taking a look at the FalconSpeed and ATSpeed software in Ghidra earlier today, they definitely work in different ways. The ATSPEED software definitely uses $FFFC40/$FFFC80 to communicate as per the Atari STE+ service manual, but FalconSpeed seems to be mapped in a different way, which wasn't entirely clear. It almost looked like it was using similar memory locations to the IKBD/MIDI ACIAs to communicate (using the odd bytes as opposed to the even).
Yes, that's a very fair point. With so little logic on the board itself it does kind of preclude playing nicely with anything else in RAM, I suppose.Don't forget that TOS and DOS will both be fighting over memory locations (they share the same address space), so it's a non trivial problem to switch between the two. Ideally, you'd want to be able to remap the x86's memory accesses to an arbitrary block allocated by TOS, but the logic to do that (without an MMU on the CPU) would be complex.
I attach what I have so far. I think the PAL ones are wonky as the pins don't line up. I've tried to name the GAL ones appropriately, however.I suspect IC6 is doing something interesting with the high byte of the addresses to help, though. My disassembly of the FalconSpeed (and ATSpeed) software suggests the Atari loads the BIOS in at $38000, although the 286 will (IIRC) access it at F000:FFF0, so something must be happening. The decoded equations will be interesting,
It's certainly an exercise in minimalism and, with the hard disc limitations (coming in part two), it might be argued it doesn't really. :)Interestingly the reason that FalconSpeed can only access 8MB is because A23 is grounded by the 74HC573 at IC10.
It's quite amazing it actually works at all :)
Yep, there's definitely some IDE reading code in there… I need to look at in more detail…Badwolf wrote: 12 Sep 2026 22:20 Ooo, if you're looking at Ghidra (I still must learn to use that -- the few attempts I've had so far to play with it have ended in ignominy), let me know if you see anything related to IDE.
How the heck this doesn't break MIDI software I don't know…My quick bit of debugging with Hatari agrees with your ACIA discovery. Without any hardware the software will spin in a loop setting the MIDI ACIA's byte and the one above it to zero (via a word clear) then testing the keyboard+1 byte for ($e0 >> 5). Mysterious.
LAB_00011ff6 XREF[2]: 00011ff0(j), FUN_00013548:000141b0(j)
00011ff6 42 78 fc 04 clr.w (DAT_fffffc04).w
00011ffa 4e 7a 20 02 movec CACR,D2
00011ffe 08 c2 00 0b bset.l #0xb,D2
LAB_00012002 XREF[1]: FUN_0001455e:00014c5c(R)
00012002 4e 7b 20 02 movec D2,CACR
LAB_00012006 XREF[1]: FUN_0001455e:00014c5e(R)
00012006 14 38 fc 05 move.b (DAT_fffffc05).w,D2b
LAB_0001200a XREF[1]: FUN_0001455e:00014c60(R)
0001200a eb 4a lsl.w #0x5,D2w
LAB_0001200c+2 XREF[0,1]: FUN_0001455e:00014c62(R)
0001200c 0c 02 00 e0 cmpi.b #E0h,D2b
LAB_00012010+2 XREF[0,1]: FUN_0001455e:00014c5c(R)
00012010 66 00 18 6a bne.w LAB_0001387c
00012014 eb 5a rol.w #0x5,D2w
LAB_00012016 XREF[1]: FUN_0001455e:00014c5e(R)
00012016 02 42 00 01 andi.w #0x1,D2w
LAB_0001201a XREF[1]: FUN_0001455e:00014c60(R)
0001201a 84 38 fc 07 or.b (DAT_fffffc07).w,D2b
* FUNCTION *
undefined __stdcall16far BiosEntry()
undefined <UNASSIGNED> <RETURN>
BiosEntry XREF[1]: f000:fff0(c)
f000:9309 fa CLI
f000:930a 90 NOP
f000:930b 90 NOP
f000:930c b0 8f MOV AL,0x8f
f000:930e e6 70 OUT 0x70,AL
f000:9310 eb 00 JMP LAB_f000_9312
LAB_f000_9312 XREF[1]: f000:9310(j)
f000:9312 e4 71 IN AL,0x71
f000:9314 8a e0 MOV AH,AL
f000:9316 80 fc 09 CMP AH,0x9
f000:9319 75 1a JNZ LAB_f000_9335
Thanks, I'll take a look. The schematic suggests IC6 is probably the key one…I attach what I have so far. I think the PAL ones are wonky as the pins don't line up. I've tried to name the GAL ones appropriately, however.I suspect IC6 is doing something interesting with the high byte of the addresses to help, though. My disassembly of the FalconSpeed (and ATSpeed) software suggests the Atari loads the BIOS in at $38000, although the 286 will (IIRC) access it at F000:FFF0, so something must be happening. The decoded equations will be interesting,
:)It's certainly an exercise in minimalism and, with the hard disc limitations (coming in part two), it might be argued it doesn't really. :)
