Page 2 of 2
Re: A new addition - Teleng Colourstars
Posted: 14 May 2026 14:30
OK, so I found a bit of round plastic and got the little lathe out and made a new button :)
- IMG20260514142131.jpg (218.31 KiB) Viewed 806 times
Needs a little tweak as a bit long but overall should do nicely. I need to find a spring too.
Posted: 14 May 2026 15:00
And the finished job looks quite reasonable IMHO. Works great too :)
- IMG20260514145712.jpg (308.67 KiB) Viewed 801 times
Just need to give the unit a good clean up now.
As it happens I noticed that I
could have replaced it with a full switch like the pic I showed above, but the replacement button top turned out so well I don't need to. Also I'd have had to peel the label and I wasn't keen on the idea.
@stephen_usher it
did turn out to be a generic switch when I looked a bit closer :)
Posted: 14 May 2026 23:23
by HigashiJun
Looks good !
:bravo:
Posted: 15 May 2026 10:17
HigashiJun wrote: 14 May 2026 23:23
Looks good !
:bravo:
Thank you sir :)
