Page 2 of 6
Re: Different compilers for compiling TOS ?
Posted: 24 Oct 2025 11:26
On to the next problem then..
ah...
:ball:
Posted: 24 Oct 2025 11:32
:sigh:
So searching through the original installer I found it..
Now what ? :lol:
Posted: 24 Oct 2025 13:19
What a faff! had to install nano... wget installs but does nothing at all.
Did a test program:
mkdir ~/atari_projects
cd ~/atari_projects
 nano hello.c
#include <osbind.h>
int main() {
    Cconws("Hello, Atari ST from Cygwin!\r\n");
    Cconin(); // Wait for keypress
    return 0;
m68k-atari-mint-gcc -m68000 -I/opt/cross-mint/m68k-atari-mint/include -o hello.tos hello.c
:girldance: :cheer: :girldance: :cheer:
So how the heck do I now compile the operating system :lol: :roll:
:dizzy:
Well MAKE doesn't seem to do anything, silent output like WGET. Been working though with Grok. We both clueless now.. So no idea.. :(
Posted: 24 Oct 2025 14:32
by stephen_usher
Goodness knows how the original build process will work with GNU C. You'll need the flag -mshort so that ints are 16 bits rather than 32 bits for a start.
Posted: 24 Oct 2025 15:01
stephen_usher wrote: 24 Oct 2025 14:32 Goodness knows how the original build process will work with GNU C. You'll need the flag -mshort so that ints are 16 bits rather than 32 bits for a start.
Yep, there could be a whole bunch of stuff wrong for all I know. Not really worth the time screwing around with it all. I'll stick to what I was doing originally as it all works.
Posted: 24 Oct 2025 15:25
by Badwolf
exxos wrote: 24 Oct 2025 13:19 So how the heck do I now compile the operating system :lol: :roll:
I've just tried the process from scratch on my box:-
mkdir /tmp/osbuildtest
cd /tmp/osbuildtest
Choose a path appropriate for you.
git clone https://github.com/th-otto/tos3x.git
Git will probably be available as a cygwin package if it's not already installed. You could do it with a curl/wget instead.
cd tos3x
Pretty self-explanatory.
make
And it just worked.
dh219@gin:/tmp/osbuildtest/tos3x$ ls -l glue/*.img
-rw-r--r-- 1 dh219 dh219 524288 Oct 24 15:20 glue/tos306de.img
There it is.
Now you'd have to set it up for 2.06 and UK (or whatever) then apply your changes, but it's all in there.
Posted: 24 Oct 2025 15:29
@Badwolf I'm not using the files from git though. I patched loads of stuff so all the files are on my PC.
I gave up with Grok and GPT said.
My files did likely come from that same repo anyway. But would have been some years ago now.
Running MAKE or MAKE CLEAN does nothing at all. Totally silent output.
Posted: 24 Oct 2025 15:37
$ git clone https://github.com/th-otto/tos3x.git
Cloning into 'tos3x'...
fatal: remote helper 'https' aborted session
Even that doesn't work :(
Downloaded manually.. still does nothing.
:mad:
Get out of this rabbit hole now then I guess.....
I mean if the new compiler isn't going to drastically optimise stuff to be more efficient, than is probably just not worth all the hassle anyway..
Mostly I was just trying to find something a bit quicker and simpler and more modern to compile with, but it's just turning into another software nightmare I just cannot be bothered with :)
Posted: 24 Oct 2025 16:54
by Badwolf
exxos wrote: 24 Oct 2025 15:29 @Badwolf I'm not using the files from git though. I patched loads of stuff so all the files are on my PC.
Start with the git version. Apply your changes.
And *for the umpteenth time*, stop using LLMs to try to solve your problems! Of course it's not running TTP files. What nonsense. That's the Atari version.
Anyway, I just tried downloading the zip instead (https://github.com/th-otto/tos3x/archiv ... master.zip) and, apart from cd to a different directory name, it just made first time again.
You haven't shown us what's in your tos3x directory, BTW.
Oh, it's jsut occurred to me perhaps cygwin has two types of make. Try running 'gmake' instead?
Posted: 24 Oct 2025 17:27
by dml
exxos wrote: 24 Oct 2025 13:19 What a faff! had to install nano... wget installs but does nothing at all.
Did a test program:
cd ~/atari_projects
 nano hello.c
It might be helpful to know that the cygwin drives are also just Windows directories - you can use nano (or vim or anything else) from the cygwin shell, or you can edit the code on the disk in Windows using any editor or IDE.
> explorer .
That should open a windows file explorer where your sources are so you can mess with them directly.
(yes, you can run normal windows .exe programs from cygwin shell)
But there are some hazards - Windows CRLF line endings sometimes can creep in from your editor/IDE and its easy to get mixed up with / posix directory separators and \ Windows separators. Cygwin will tolerate both but the programs you are running there might not. Also permissions might be an issue in some cases where they matter since Windows file operations can change them under cygwin's feet. Usually this isn't an issue for compiling source projects though.
