Page 2 of 4
Re: USB keyboard adapter
Posted: 23 Jun 2025 19:20
TheNameOfTheGame wrote: 23 Jun 2025 16:56 Ok, I see what you were saying. It's semantics that that got a bit confusing. I don't care if the usb keyboard is ps/2 or non-ps/2 really. Any usb keyboard non-ps/2 or ps/2 can go through the github project adapter. That's what I am looking for at the end of the day. Thanks for all the help guys. Appreciate it.
Yeah, that's all it is, as long as you got there in the end :)
Posted: 23 Jun 2025 19:36
by agranlund
@TheNameOfTheGame ,
There's also HIDMan:
https://github.com/rasteri/HIDman
And the smaller HIDMan-mini/micro fork:
https://github.com/serisman/HIDman-mini
Posted: 23 Jun 2025 22:40
by peters
I tried building this a few years ago but couldn't get it to work
https://github.com/ChrisDeadman/Usb2Ps2Mouse
Posted: 23 Jun 2025 23:55
by TheNameOfTheGame
Thanks guys, I'll take a look at those projects also. Cheers.
Posted: 24 Jun 2025 11:21
by peters
The Hidman solution looks good but I would have to get an assembled PCB and I assume there is a minimum other quantity from PCBway.
Posted: 24 Jun 2025 18:29
by peters
I've never looked into PCBway ordering before.
If I understand correctly I can order 5 Hidman pcbs with one of them assembled and the total is $34 which seems cheap. Unless I'm doing something wrong.
I can 3D print the front and back panels and maybe the case as well.
Posted: 24 Jun 2025 22:42
by viking272
TheNameOfTheGame wrote: 23 Jun 2025 14:06 Does anyone know of a USB->PS/2 adapter or solution available?
I am looking to hook up my Hades060 via USB keyboard.
Been looking around for a convertor but coming up empty so am stumped. Any ideas?
What about Alan H’s ImpoSTer?
https://atarikit.co.uk/
Posted: 25 Jun 2025 12:29
by peters
https://www.pcbway.com/project/sharepro ... fb5d5.html
Anyone else interested in either an assembled HIDman or a PCB ?
Posted: 26 Jun 2025 11:30
by peters
Any PcbWay experts around ?
I selected PCB+assembly and click Add to cart.
It offers a lot of PCB options which I've not changed apart from adding a quantity of 1.
I click Calculate and it shows the price. I think this is for one assembled and 4 or 5 blank pcbs.
Is that it ? Have I missed anything ?
Posted: 26 Jun 2025 16:12
by DoG
peters wrote: 26 Jun 2025 11:30 Any PcbWay experts around ?
I usually don't use PCBway so I'm no expert but I did order 5 fully assembled HIDman in February. I can't remember but PCB is most often done in increments of 5. So 5 PCB is the smallest order you can do. Then how many you populate with components is up to you. I did 1,6mm thick (standard) and in black.
It takes a while. 1-1,5 month. You will also get a quotation back for prices of each components. I got also got a mail stated that two pads was to small to get solder mask in between the pads on the 559 chip. They where not used so didn't matter anyway. But since all pads is the same it's quite odd when you get those mail back. Just answer "it's fine, please proceed".
Front and back panels is also PCB and I ordered mine from JLCPCB in black, 1mm thick but you can use PCBWay for that as well. The 3-color-LED shine through in one part of the panel that is not coated on the back. Also remember to order screws. The ones listed was to small for the 3D print I did for some reason. But I ordered the case in black resin from JLCPCB. So I ordered M3,5 screws and a 3,5 tap. But the original is probably fine if you use the aluminium. Also the 3D file I downloaded for the case was 80mm long instead of the 40 that is the desired length. So I had to cut it with a hacksaw/dremel when I got the surprise when I opened the package.
