Page 2 of 5
Re: Possible sale of 2 xShort ST STM 520 4MB with ST536 built in
Posted: 27 Feb 2025 11:06
by mrbombermillzy
Thanks for the pics @PhilC
I guess fitting a VOFA card is out of the question then! :lol:
It looks like a twin shifter board might fit over the shifter...I cant see but it *looks* socketed. Is that correct? (BTW, whats the grey thing/mod north of the shifter?!)
Its a darn shame about the IDE height. Like mentioned, could really have done with the headers under the board instead.
This might sound like a silly question, but is the TF board socketed or have you soldered it in?
If not, that might be another possible solution, if you can figure the lowered height problem this then presents at the top/connectors end. :roll:
Posted: 27 Feb 2025 11:16
by PhilC
@mrbombermillzy Agranlund did a crazy card which had a TF536, hand wired ISA graphics adaptor and a blitter. But otherwise, I don't think one will fit.
If you put the IDE on the bottom as it is, it flips the polarity of the IDE, pin 1 being pin 2 position etc But yes, would be great on the bottom but would need a lot of re-routing to do so easily.
One of the Amiga guys did do a Relocator for the IDE on Amiga but that wouldn't help in this case.
Posted: 27 Feb 2025 11:25
by mrbombermillzy
Sorry, was completely joking about the VOFA card. However, kudos to @agranlund for actually pulling it off! :lol:
Yeah, I realise the IDE signals would be swapped. There always seems to be a routing issue, whatever you do. Like exxos says, on another board, if the IDE header was actually on the bottom, it might e.g hit an IC.
Didnt @Steve have a setup like this? Did he encounter this problem and find a solution?
Posted: 27 Feb 2025 11:29
by PhilC
mrbombermillzy wrote: 27 Feb 2025 11:25
Yeah it might if you fit it underneath. I think if it was moved back a bit it would still be fine for other ST boards as well, other than the STF&M which would require a Relocator to miss the Shifter box anyway.
Posted: 27 Feb 2025 11:42
by mrbombermillzy
PhilC wrote: 27 Feb 2025 11:29
Well yeah, that would do the trick. :)
However, Im not sure if Im missing something here, but wouldnt this be a difficult task? Change the board design, remanufacture the board(s) and then resolder/setup the components?!
Or does Exxos tweak/remanufacture boards very often and you are his main ST536 builder? In which case, maybe not so much hassle! :lol:
Posted: 27 Feb 2025 11:55
by Steve
Yeah for my short ST I followed what @coonsgm did and soldered the IDE header on the bottom.
Posted: 27 Feb 2025 12:04
by PhilC
Steve wrote: 27 Feb 2025 11:55
How did you get over the pins being in the wrong place?
Posted: 27 Feb 2025 12:06
by agranlund
mrbombermillzy wrote: 27 Feb 2025 11:06
If there’s a will there’s a way :)
- IMG_3437.jpeg (90.9 KiB) Viewed 749 times
”some assembly required”
- IMG_3438.jpeg (182.92 KiB) Viewed 749 times
Posted: 27 Feb 2025 12:11
by mrbombermillzy
agranlund wrote: 27 Feb 2025 12:06
Good grief!
:dizzy:
:lol:
Posted: 27 Feb 2025 13:16
by Steve
PhilC wrote: 27 Feb 2025 12:04
I think I had to desolder the header on the CF card and resolder them on the underside too.
