Page 2 of 3
Re: Upgrading C103175 Rev. 1 520STFM to 1MB - how exactly?
Posted: 04 Oct 2025 18:07
Posted: 18 Oct 2025 12:13
by jurassicman
Yes... they seem exactly the same I ordered... I'm still waiting for them, though.
In the meantime, is there somewhere a list of the axial capacitors needed in order to recap this model of mainboard?
Posted: 18 Oct 2025 21:11
by frank.lukas
-7 = 70ns
-10 = 100ns
... for a standard 8Mhz 68000 Atari ST 100ns is fast enough. Atari use 150ns or 200ns.
Posted: 19 Oct 2025 01:21
jurassicman wrote: 18 Oct 2025 12:13
In my experience the ST generally doesn't need recapping, I personally wouldn't worry too much unless you can see capacitors that look like they're leaking or are bulging, I wouldn't bother.
In any event, just read the values off the caps on the board. My personal preference is to go for 105c caps instead of 85c as it means you have a better temperature range from any replacements.
Posted: 19 Oct 2025 08:54
by jurassicman
Thanks for your replies... the capacitors look ok but I was wondering if it would have been wise to replace them as I did with those in the PSU.
I had a look online and axial capacitors are a bit more expensive than the radial ones and not so common so probably it would be just a waste of time at the moment... I'll patiently wait for the memory chips... :)
Posted: 19 Oct 2025 16:04
by ijor
frank.lukas wrote: 18 Oct 2025 21:11
Are you sure Atari ever used 200ns RAM chips in any ST machine? At least in theory, 200ns RAM chips are not fast enough.
Posted: 19 Oct 2025 18:07
by frank.lukas
ROM chips 200ns and RAM 150ns I think but I might have mixed something up?
Posted: 26 Oct 2025 09:43
by jurassicman
I finally got the chips, I did mount them on the sockets but my system still sees only 512 KB of RAM... Am I missing something?
The R73, R72 and R71 were already populated as the C25, C26, C27 and C28... please help... :)
Posted: 26 Oct 2025 09:50
by jurassicman
Posted: 26 Oct 2025 10:20
by jurassicman
As per the RAM speed, as visible in my picture and as you can read
here the original chips speed is 100ns like those I did buy.
