Page 2 of 2
Re: Mice - Alternatives and recommendations
Posted: 04 Mar 2018 10:12
Darklord wrote: 04 Mar 2018 08:04 I know they are expensive ($30+), but the best replacement mouse I've found is
the one from Best Electronics. Best "feel" ever, in my humble opinion. :)
Yes, I suppose it seems expensive, especially if you have to add on shipping from the states.
I recently got 2 PS2 mice for under £10, USB but with PS2 adapters, and a USB adapter by Kevin Mount. Total cost for one ST (Or Amiga, they work with both) is about £20. That's about $27 when you convert, so in reality, not much different.
Must admit, I like the look of the SmallyMouse, very small indeed!
Posted: 04 Mar 2018 20:05
by Bobrane
Hi, Cyprian asked me how to buy the SmallyMouse2.
As a young member, i can't reply to his p.m yet, so here is my answer :
Olivier doesn't have an e-shop because he doesn't have the time to do so.
To buy something from him, you just have to write him an email.
Look at this page : http://www.gossuin.be/index.php/shop
@Exxos : I hope you won't mind if i link here another shop.
Posted: 06 Mar 2018 08:54
I had a reply in relation to the Jerry+.
Apparently to configure for whichever machine you're using it with, you need to do the following:
"Hold left button before computer startup and then quickly press (while the holding left button) the right button 5-6 times."
It doesn't seem to work for me, so maybe the 5v line is low on my test ST. I'll try it again on a different ST, but for now it's plugged into my A1200, whose mouse is becoming a bit tired.
I have 2 other modern mouse adapters I can use with my ST's, so it's really not a problem.
Posted: 08 Mar 2018 19:32
by stephen_usher
rubber_jonnie wrote: 06 Mar 2018 08:54 I had a reply in relation to the Jerry+.
Unfortunately I had to try several times as you have to get the rate of clicking 5-6 times *just right* and within a small time window. It's not the best way of doing configuration. You have to feel that a DIP switch would have been miles better.
Posted: 08 Mar 2018 23:55
stephen_usher wrote: 08 Mar 2018 19:32
I guess I will try again, and as for that DIP switch, well I can't say I disagree.
