Re: Bad reads after bus resistor replacements with ACSI2STM
Posted: 24 Oct 2023 11:06
Unfortunately no two STs are the same and you have to be prepared to treat each machine individually. It can be very frustrating when chasing down problems, and the best advice I can give is to do one thing at a time, check the outcome, and if no change move on to the next thing.
Unfortunately with these old machines you are always fighting to keep things reliable, it's just part of the landscape.
Like @exxos said, using the ICD driver is not the best, and HD11 or PPs driver are the two I'd recommend.
Also, if you're soldering in the resistor packs in parallel then you need to be inspecting very closely afterwards to ensure there are no solder bridges between pins. Bridges can be obvious, but can also be very fine whiskers of solder that are difficult to see without magnification.
Looking after retro kit requires a lot of patience and it can be time consuming, so you do need to be committed, but it is also very rewarding when you can repair something, so it is worth sticking with.
