Page 2 of 3
Re: Two Falcon 030's Rev B & Rev D/C
Posted: 23 Jul 2023 14:57
by Steve
I think it is because it seems to have a stock Clab clock patch and the audio mods. @gari it would be a 'no brainer' to use the Clab version since it has all the cubase audio mods done for line level etc.
Posted: 23 Jul 2023 20:45
by gari
gari wrote: 23 Jul 2023 10:46 EDIT: I (Icky) have removed the zip and placed images in-line to aid forum users to view
Thanks, I'm curious about why my images appear corrupt and do not display, if it's on my side or a restriction for new members.
Posted: 23 Jul 2023 21:07
by gari
mikro wrote: 23 Jul 2023 14:33 Thanks! Are you sure the rev.B isn't a C-Lab MK2/MKX Falcon? The board revision and serial number would imply that.
Thanks for your interest! I couldn't determine if it's a C-Lab version though after reading a few threads it looks similar. I always thought C-Lab Falcons were rebadged on the top casing or had a sticker with a serial but never saw one before. Puzzling too is the fact it came with a Steinberg SMP II midi/smpte clock usually for a cubase environment but C-Labs were bundled with Notator if I remember correctly? Haven't used an Atari since 96 when I made techno tracks as a kid lol.
Posted: 24 Jul 2023 07:12
by mikro
Hmm so your case looks like the Atari one? I guess you are sure that this is the original one?
It's possible that C-Lab have been producing new motherboards and putting them in old cases (which seems unlikely, your case has a s/n from 10/94) or that the last batch from atari (09/1994) already had those 700015-003 production numbers, who knows.
Posted: 24 Jul 2023 09:12
by Steve
@mikro I've come across instances where C-Lab Falcons have been re-cased back into original Falcon cases. I guess this might happen sometimes where studios purchased Falcons / C-Lab Falcons, rack mounted them & then later on put them back in whatever case they find in storage to sell off.
@gari just because it came with a steinberg adapter doesn't mean much, perhaps the previous owner preferred Cubase, simple as that. I'm fairly certain this is a C-Lab motherboard since it has all the standard C-Lab motherboard patches, even the weird cable patch under the motherboard and the cable patch on the SCSI > Ajax controller. I've only ever seen these on C-Lab boards.
Posted: 26 Jul 2023 12:00
by gari
mikro wrote: 24 Jul 2023 07:12 Hmm so your case looks like the Atari one? I guess you are sure that this is the original one?
Yes the casing is a normal Falcon. The seller mentioned it had been worked on so I guess the C-Labs mods could have been replicated or the casing switched as mentioned below.
Steve wrote: 24 Jul 2023 09:12 just because it came with a steinberg adapter doesn't mean much, perhaps the previous owner preferred Cubase, simple as that. I'm fairly certain this is a C-Lab motherboard since it has all the standard C-Lab motherboard patches, even the weird cable patch under the motherboard and the cable patch on the SCSI > Ajax controller. I've only ever seen these on C-Lab boards.
Good to know it's probably a C-Lab board. Are there major improvements on a rev D from a rev B that would make it unwise to let it go? The C-Lab looks like a keeper for my use.
Posted: 26 Jul 2023 15:09
by kohli79
Here are two pictures of my MKII - C-Lab. Maybe helpful for one or the other.
Appears to be a Rev. A.
Greetings Uwe
Posted: 26 Jul 2023 15:31
by Steve
@gari all C-Lab mother boards are newer than any Atari motherboard. As C-Lab bought the rights when Atari ceased production. So your Rev B will be newer than your Rev D. As far as I know.
Posted: 27 Jul 2023 09:17
by mikro
@kohli79's photos is a good example why those PCB s/n shouldn't be taken as gospel. It's a normal (Atari) board with their upgrades. I guess they were recasing / mounting Atari boards in parallel to producing new ones.
Posted: 31 Jul 2023 01:45
by Rustynutt
Probably discussed long ago.
What happened to the files required to produce the motherboard?
Know CLAB went out on a whim really.
And the injection molds requires to make cases? Was that all left behind in Taiwan?
