Page 2 of 16
Re: Something experimental - A5000 mouse ball replacement.
Posted: 15 Mar 2023 22:21
stephen_usher wrote: 15 Mar 2023 22:16 I guess you could try repeatedly dipping a steel ball in latex and then vulcanising it. I seem to remember that is how many of the original mouse balls were made.
I'll be honest, I have thought about doing that too, say with a 17mm or 18mm steel ball to allow for some depth in the latex coating.
I am also considering if it might be feasible to cast a 20mm resin ball with a 15mm ball bearing inside it.
Posted: 19 Mar 2023 16:16
Ok, so I got round to attempting the mould making this weekend!!!
I stood the ball on a small piece of plastic to make the 'sprue' where I can pour in the epoxy once the mould is ready:
Mixed up the RTV moulding goo:
Then combined the two:
This is a first attempt and I do have enough for probably 3 moulding attempts.
I'm going to allow 24hrs for it to cure, I'm confident I got the mix ratio correct, it's 100-2 ratio by weight and I weighed it on some digital scales before mixing.
I'll report back on the results. And yes, I know there were bubbles, I've done some tapping around the periphery and most seem to have gone now.
Posted: 21 Mar 2023 11:59
Progress!!
I gave the RTV about 60 hours to cure (Mostly because I forgot to check it :) ) and it's looking good now the original ball is removed:
Next up I need to try and pour some resin and see what's what :)
Posted: 22 Mar 2023 09:31
by Badwolf
Great work so far. I love to see this kind of thing.
Nervously awaiting the next instalment! :)
Posted: 22 Mar 2023 19:00
Badwolf wrote: 22 Mar 2023 09:31 Great work so far. I love to see this kind of thing.
Hopefully you won't have to wait long 😁
Posted: 23 Mar 2023 10:17
@Badwolf
You're in luck, I poured the resin just before 0900 this morning :)
It will be a gel in 6 hours and I should be able to de-mould in 12 hours, full hardness is in 24 hours. I'll probably just leave it until tomorrow morning which'll be this time tomorrow. How exciting!!
Posted: 23 Mar 2023 10:25
by Badwolf
What did you do today, daddy? Well, I vicariously enjoyed a bloke on the internet making his ball harden over the course of a day.
:shock:
Posted: 23 Mar 2023 10:26
Badwolf wrote: 23 Mar 2023 10:25 What did you do today, daddy? Well, I vicariously enjoyed a bloke on the internet making his ball harden over the course of a day.
:shock:
Ooooer missus!!
Posted: 23 Mar 2023 10:36
by HigashiJun
rubber_jonnie wrote: 23 Mar 2023 10:17 full hardness is in 24 hours.
Could be quite misleading out of its context...
Posted: 23 Mar 2023 10:41
HigashiJun wrote: 23 Mar 2023 10:36
Crikey, you lot are a bit naughty this morning!!!
