Re: 320x240 12-bit chunky display on an ST
Posted: 07 May 2022 15:38
You may take Michael, spin him around, return him & I would still accept this Michael.
We welcome retro users & hardware gurus alike! Come and join the party :)
https://www.exxosforum.co.uk/forum/
I was thinking NVDI. I've written some experimental drivers for it, perhaps it could be tuned a bit to work on your config.Badwolf wrote: 07 May 2022 13:20 tell me how? Or point me at a manual. I didn’t know how to tell the VDI what the hardware was capable of so just let FVDI do it for me (modifying the Line A variables let me do 640x480 16 col planar, but I didn’t want that).
Since there's only one resolution, it doesn't really matter. ;)shoggoth77 wrote: 07 May 2022 17:08I was thinking NVDI. I've written some experimental drivers for it, perhaps it could be tuned a bit to work on your config.Badwolf wrote: 07 May 2022 13:20 tell me how? Or point me at a manual. I didn’t know how to tell the VDI what the hardware was capable of so just let FVDI do it for me (modifying the Line A variables let me do 640x480 16 col planar, but I didn’t want that).
Question is - since this isn't a Falcon, the resolution dialog will be kind of limited.
- Framebuffer is at C00000 to C7FFFFTech questions:
- is the framebuffer memory mapped?
- what's the relation to the shifter - does this thing function like graphics cards do on the platform, i.e. in parallel with the shifter?
That would be great. There's probably enough there to do a 15 bit bus at 50MHz.agranlund wrote: 07 May 2022 22:53
Basically, what immediately popped into my head was something along the lines of: toss my existing ET4000 and hook some modified version of your invention up to the IDE port of the TF536 (with special firmware)
I'm not using the TF536 IDE port anyway and my ST is already modified for internal graphics card so it could slot in quite nicely.
There's nothing to stop me trying this at 16MHz, I suppose.agranlund wrote: 07 May 2022 22:53 Do you think it would benefit from sitting on anything faster than the ST bus?
While I do like my internal ET4000 it's not exactly a speed demon being an ISA card on an 8Mhz bus :)
How many lines do you have control over on the IDE port? If there are 16 data bits on there and seven ground, that's only 17 pins left. Not enough for the addressing.Basically, what immediately popped into my head was something along the lines of: toss my existing ET4000 and hook some modified version of your invention up to the IDE port of the TF536 (with special firmware)
