Page 2 of 10
Re: Whoops, I did it again! VIC-20 on the way...
Posted: 16 Feb 2022 14:28
Hmm, interesting:
- IMG_20220216_142552.jpg (529.91 KiB) Viewed 2310 times
Very nice work here, I suspect it's factory, but don't know enough to say what it's for. I'm guessing to replace missing or bad tracks on this version of mobo.
Posted: 16 Feb 2022 14:58
by stephen_usher
Seems to be using a few unused OR and NOT gates on the '02 and '04.
I can't see any references to those bodges on-line.
Posted: 16 Feb 2022 15:00
stephen_usher wrote: 16 Feb 2022 14:58
It does seem to be, yes. Will have a look later too, see if I can find anything, Makes you wonder if some tracks were missed out.
Posted: 16 Feb 2022 15:02
by stephen_usher
I think I have an answer...
From what I've just read Commodore used larger RAM chips than was required as they had an over-stock, so I think this mod is trying to use the upper half of the RAM chips as a memory expansion. However, this was from Stack Exchange so it's probably wrong.
Posted: 16 Feb 2022 15:17
stephen_usher wrote: 16 Feb 2022 15:02
Interesting. I'm seeing only 3.5KB so it isn't using anything extra, or at least showing anything extra. Will dig more after work :)
Posted: 16 Feb 2022 15:18
by stephen_usher
Can the VIC=20 basic see more than that? I don't think that it can.
Posted: 16 Feb 2022 15:23
by stephen_usher
I've just posted that picture elsewhere to see if they know what the mod is.
Posted: 16 Feb 2022 15:24
stephen_usher wrote: 16 Feb 2022 15:18
It can be expanded via the cartridge slot to 32KB from what I've read, though I will be looking at other internal options.
stephen_usher wrote: 16 Feb 2022 15:23
Cool thanks. I did the same.
Posted: 16 Feb 2022 15:27
by stephen_usher
